June 2, 2008, 05:17 |
Hi,everyone,
After I runni
Vivien
Rep Power: 17 |
Hi,everyone,
After I running a solver, I got 'T' for each timestep, then I manage to run another sover based on T in each time step. Although I set start time to be zero and endtime to be 50, time step is 0.5 in controlDict, it always runs from t=50s, anybody know why this is happening? Thanks, Vivien |
June 2, 2008, 05:23 |
Hi Vivien,
What does it say t
Dragos
Rep Power: 20 |
Hi Vivien,
What does it say the startFrom variable in your system/controlDict file? In my case I have: startFrom latestTime;which basically says "start from the last time you find in the case directory". So, if you have something similar, and your last time directory is 50, than it should start from 50s. If you want to change it, replace latestTime with the time you want, 0 for instance. I hope this is helpful, Dragos |
June 2, 2008, 05:28 |
After running the solver, you
Mark Olesen
Rep Power: 40 |
After running the solver, you have the results. You can continue calculating with the same solver, or a new solver, from a particular time
controlDict> startFrom (startTime | firstTime | latestTime) If you want, you can also post-process each of the time results with your own utility. If you wish to somehow use your temperature results for a second solver, you'll need to move the old results out of the way (so they aren't overwritten), restart from time=0 and have a time-varying boundary condition or some other field that uses the previously calculated temperatures. |
June 2, 2008, 05:55 |
Hi, I see what is going wrong.
Vivien
Rep Power: 17 |
Hi, I see what is going wrong... I missed a semicolon after the application...
Thanks for the reply! vivien |
cfx time scale control | Kordou | CFX | 2 | September 22, 2008 11:07 |
Iteration control | kdarc | OpenFOAM Running, Solving & CFD | 5 | September 24, 2007 11:27 |
Control Volume | Sangeeta | FLUENT | 8 | March 7, 2007 08:08 |
How to set and control the turbulence in CFX? | Wei | CFX | 8 | November 28, 2006 04:41 |
Time Stepping Control | Dave | CFX | 2 | September 5, 2002 05:39 |
