Is it possible to obtain wallY%23601 for an airfoil |
May 26, 2008, 12:35 |
Hi foamers,
in the last wee
Leonardo Nettis
Hi foamers,
in the last weeks I'm struggling with a rae airfoil for which I would like to obtain wall y+ <1. Unfortunately since this requirement is very strong for the mesh generation (the first cell near the wall should be very small) this gave me a lot of problems to get the convergence. Actually in all my trials the continuity error tends to explode, probably driven by the pressure residuals. On the other side when I've tried to modify the mesh in order to using the wall functions, so increasing the wall-adiacent cell size, I got no problems!! Therefore now I'm asking myself if it possible to reach this objective! If somebody did something concerning this issue, please help me! thanks a lot dino |
May 26, 2008, 12:56 |
Yes, it should be possible. Wh
Anonymous
Yes, it should be possible. What are you using for mesh generation? To assure you've resolved the boundary layer, you want your first cell distance to be between 10^-5 - 10^-6 of the aerofoil chord with a stretching ratio no greater than 1.2-1.3. Using wall functions is an easy problem since boundary layer resolution is no longer required and your cell quality will be improved. Don't waste your time with wall functions if you can afford to. All major research in wings, rotors, and aircraft has the boundary layer resolved. Anything less than 10 points in there and you can expect to face a lot of scrutiny.
So, can you tell us what solver, turbulence model you were using? What is your cell skewness and general quality like? Has your aerofoil got a blunt trailing edge or does it meet at a point? What mach number are you working at? What angle of attack? We need more information, please. |
May 26, 2008, 13:35 |
These are the info you require
Leonardo Nettis
These are the info you required:
solver: simpleFoam turbulenceModel: LaunderSharmaKE near wall cell size: 1e-5 Ma=0.1 Re=1e6 trailing edge: blunt (lenght: 3e-4 m) angle of attack:2.8 checkMesh ---------------------- Mesh stats points: 212020 edges: 528678 faces: 421982 internal faces: 209962 cells: 105324 boundary patches: 8 point zones: 0 face zones: 0 cell zones: 1 Number of cells of each type: hexahedra: 105324 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Topological cell zip-up check OK. Face vertices OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface empty1 105324 106010 ok (not multiply connected) trailing 31 64 ok (not multiply connected) outlet 229 460 ok (not multiply connected) bottom 312 626 ok (not multiply connected) top 312 626 ok (not multiply connected) wing 259 520 ok (not multiply connected) inlet 229 460 ok (not multiply connected) empty2 105324 106010 ok (not multiply connected) Checking geometry... Domain bounding box: (-20 -20 0) (20 20 0.001) Boundary openness (3.98952e-20 -1.72053e-23 1.83245e-14) OK. Max cell openness = 4.4418e-14 OK. Max aspect ratio = 992.012 OK. Minumum face area = 1.00474e-10. Maximum face area = 0.182054. Face area magnitudes OK. Min volume = 1.00474e-13. Max volume = 0.000182054. Total volume = 1.59992. Cell volumes OK. Mesh non-orthogonality Max: 89.6288 average: 35.0138 *Number of severely non-orthogonal faces: 32206. Non-orthogonality check OK. <<Writing 32206 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 2.4549 OK. *Edges too small, min/max edge length = 1.1e-06 0.4924, number too small: 20938 <<Writing 20078 points on short edges to set shortEdges All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : average = 1 min = 1 All face flatness OK. Mesh OK. ----------------------------- Iteration Trend -------------------- Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 1.82607e-07, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 1.78752e-07, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = 0.00956934, No Iterations 65 GAMG: Solving for p, Initial residual = 0.0961131, Final residual = 0.000860428, No Iterations 29 GAMG: Solving for p, Initial residual = 0.171639, Final residual = 0.00170798, No Iterations 21 time step continuity errors : sum local = 0.000365398, global = -0.000104773, cumulative = -0.000104773 DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 1.38442e-06, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 1.46551e-06, No Iterations 1 ExecutionTime = 7.3 s ClockTime = 7 s Time = 2 DILUPBiCG: Solving for Ux, Initial residual = 0.0437159, Final residual = 1.27017e-05, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.104176, Final residual = 2.99386e-05, No Iterations 1 GAMG: Solving for p, Initial residual = 0.748567, Final residual = 0.00722813, No Iterations 34 GAMG: Solving for p, Initial residual = 0.331249, Final residual = 0.00324074, No Iterations 20 GAMG: Solving for p, Initial residual = 0.497473, Final residual = 0.00428006, No Iterations 21 time step continuity errors : sum local = 0.00220773, global = 0.00049871, cumulative = 0.000393937 DILUPBiCG: Solving for epsilon, Initial residual = 0.0525692, Final residual = 2.73007e-14, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.300619, Final residual = 1.4153e-06, No Iterations 1 ExecutionTime = 10.98 s ClockTime = 11 s - - - - Time = 29 DILUPBiCG: Solving for Ux, Initial residual = 0.966284, Final residual = 2.5783e-08, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.929986, Final residual = 2.1638e-08, No Iterations 1 GAMG: Solving for p, Initial residual = 0.999977, Final residual = 0.00487312, No Iterations 4 GAMG: Solving for p, Initial residual = 2.33007e-23, Final residual = 2.33007e-23, No Iterations 0 GAMG: Solving for p, Initial residual = 2.33007e-23, Final residual = 2.33007e-23, No Iterations 0 time step continuity errors : sum local = 5.45356e+64, global = 1.3964e+48, cumulative = 1.3964e+48 DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 0.000757565, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.000583767, No Iterations 1 ExecutionTime = 46.32 s ClockTime = 47 s Time = 30 DILUPBiCG: Solving for Ux, Initial residual = 0.12179, Final residual = 1.03215e-09, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.119747, Final residual = 2.03625e-10, No Iterations 1 GAMG: Solving for p, Initial residual = 4.51096e-12, Final residual = 4.51096e-12, No Iterations 0 GAMG: Solving for p, Initial residual = 3.99327e-12, Final residual = 3.99327e-12, No Iterations 0 GAMG: Solving for p, Initial residual = 3.99327e-12, Final residual = 3.99327e-12, No Iterations 0 time step continuity errors : sum local = 4.86914e+49, global = -7.4534e+36, cumulative = 1.3964e+48 #0 Foam::error::printStack(Foam:stream&) in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" #3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::tmp<foam::geometricfield<double,> > Foam::operator*<foam::fvpatchfield,>(Foam::tmp<foa m::geometricfield<double,> > const&, Foam::GeometricField<double,> const&) in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libincompressibleTurbu lenceModels.so" #5 Foam::turbulenceModels::LaunderSharmaKE::correct() in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libincompressibleTurbu lenceModels.so" #6 main in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/simpleFoa m" #7 __libc_start_main in "/lib64/libc.so.6" #8 Foam::regIOobject::readIfModified() in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/simpleFoa m" Errore di virgola mobile ------------------------------------- If you need any other detail, please tell me! thanks dino |
May 28, 2008, 04:25 |
Hi Dino,
Did you manage to
Anonymous
Hi Dino,
Did you manage to get this working? Sorry for taking so long to reply. I looked at your output and a couple of things caught my eye. Firstly, why is your AMG residuals appearing three times? I thought this was only required once? Have you tried using the k-w (Wilcox or SST) and seeing if you have the same problem? Try it inviscid and see if the same problem persists. Secondly, I notice you are running at a very low Mach number. I'm not sure what type of preconditioning is used, but maybe that could be a problem. Try upping your Mach number to 0.3 and see if the problem still occurs. Thirdly, what is your mesh quality like close to the wall, especially at the trailing-edge? High skewness at the leading edge and trailing-edge can cause you a world of problems. The blunt trailing-edge can also give some issues with convergence. It might be an idea to retry it with your trailing-edge defined at a point. Let me know how you get on. |
How to obtain forces | Karimu | FLUENT | 2 | August 22, 2005 17:26 |
Compressible flow with inlet velocity Ma%23601 | klaus | OpenFOAM Running, Solving & CFD | 2 | July 3, 2005 15:43 |
HELP - How to obtain numerical values | Ravi | FLUENT | 3 | February 16, 2003 10:18 |
How to obtain.... | Sharad Dugad | FLUENT | 6 | February 13, 2002 12:14 |
how to obtain a profile ... | olivier | FLUENT | 2 | December 13, 2001 06:21 |
