TwoPhaseEulerFoam viscosity models
Old   May 20, 2008, 02:59
Default I compared the equations in th
Juho Peltola
juho is on a distinguished road
I compared the equations in the source code of the Gidaspow and Syamlal viscosity models of twoPhaseEulerFoam to those presented in the Fluent 6.3 manual.
In both models the first term equals to the collisional viscosity equation in the Fluent manual multiplied by alpha.
The other terms in the Gidaspow model also equal the Gidaspow's kinetic viscosity model in the Fluent manual multiplied by alpha.
However, in the Syamlal model the rest of the terms equal the Fluent's Syamlal's kinetic viscosity model _without_ the multiplication by alpha.
Openfoam Gidaspow = Fluent 6.3 Manual ( 23.5-63 + 23.5-65 ) * alpha
Openfoam Syamlal = Fluent 6.3 Manual 23.5-63 * alpha + 23.5-64
Gidaspow:
return rhoa*da*sqrt(Theta)*
(4.0/5.0)*sqr(alpha)*g0*(1.0 + e)/sqrtPi
+ (1.0/15.0)*sqrtPi*g0*(1.0 + e)*sqr(alpha)
+ (1.0/6.0)*sqrtPi*alpha
+ (10.0/96.0)*sqrtPi/((1.0 + e)*g0)
Syamlal:
+ (1.0/15.0)*sqrtPi*g0*(1.0 + e)*(3.0*e - 1.0)*sqr(alpha)/(3.0 - e)
+ (1.0/6.0)*alpha*sqrtPi/(3.0 - e)
Is there a reason for the difference or is it a bug?
juho is offline   Reply With Quote
Old   May 20, 2008, 04:44
Default It's an error in the Fluent 6.
Juho Peltola
It's an error in the Fluent 6.3 manual. It has been corrected in the newest manual.
In the new manual the equations are identical to twoPhaseEulerFoam's equations.
Old   May 20, 2008, 11:31
Default Good :-) A.
Alberto Passalacqua
Good :-)
A.
Alberto Passalacqua
turbulent viscosity limited to viscosity ratio... frank FLUENT 19 December 15, 2015 22:54
turbulent viscosity limited to viscosity ratio Elizabeth FLUENT 13 December 16, 2014 08:57
Two-fluid models vs mixture models for bubbly flows Hansong Tang Main CFD Forum 6 December 8, 2009 03:21
non-linear eddy viscosity models George Main CFD Forum 0 December 11, 2006 19:14
turbulent viscosity limited to viscosity ratio mukkarum FLUENT 3 May 11, 2004 04:05
