May 17, 2009, 05:54 |
#21 |
Jagmohan Meena
Rep Power: 16 |
Compiled successfully but during running the case this error came:
Starting time loop Time = 0.01 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 8.03917e-06, No Iterations 4 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 8.25025e-06, No Iterations 4 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 6.78799e-07, No Iterations 5 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 8.7112e-06, No Iterations 5 DICPCG: Solving for pd, Initial residual = 1, Final residual = 6.39622e-09, No Iterations 404 time step continuity errors : sum local = 2.35897e-11, global = 7.22445e-14, cumulative = 7.22445e-14 rho max/min : 5.28627 0.726473 incompatible dimensions for operation [T[0 0 -1 1 0 0 0] ] + [T[1 -3 -1 1 0 0 0] ]#0 Foam::error:rintStack(Foam::Ostream&) in "/usr/lib/OpenFOAM-1.5/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/usr/lib/OpenFOAM-1.5/lib/libOpenFOAM.so" #2 Foam::Ostream& Foam:perator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) at /usr/lib/OpenFOAM-1.5/src/OpenFOAM/lnInclude/errorManip.H:87 #3 void Foam::checkMethod<double>(Foam::fvMatrix<double> const&, Foam::fvMatrix<double> const&, char const*) at /usr/lib/OpenFOAM-1.5/src/finiteVolume/lnInclude/fvMatrix.C:1191 #4 Foam::tmp<Foam::fvMatrix<double> > Foam:perator+<double>(Foam::tmp<Foam::fvMatrix<d ouble> > const&, Foam::tmp<Foam::fvMatrix<double> > const&) at /usr/lib/OpenFOAM-1.5/src/finiteVolume/lnInclude/fvMatrix.C:1531 #5 main at ~OpenFOAM/jagmohan-1.5/applications/solvers/Scalar_Transport_combinations/buoyantTransportSimpleFoamNew/buoyantTransportSimpleFoamNew.C:78 #6 __libc_start_main in "/lib/libc.so.6" #7 _start in "/home/users/jagmohan//OpenFOAM/jagmohan-1.5/applications/bin/buoyantTransportSimpleFoamNew" From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) in file /usr/lib/OpenFOAM-1.5/src/finiteVolume/lnInclude/fvMatrix.C at line 1184. FOAM aborting Abandon jagmohan@biquad:/home/users/jagmohan/OpenFOAM/jagmohan-1.5/run/coude_diffusion_thermal$ |
May 17, 2009, 06:20 |
#22 |
Hi JM
the problem is located at the line 78 in buoyantTransportSimpleFoamNew.C. Check it please. Junwei |
May 17, 2009, 06:57 |
#23 |
Jagmohan Meena
Rep Power: 16 |
Yes Mr. Jumwei, These are the lines where error occurred:
solve ( fvm::ddt(T) + fvm::div(phi, T) - fvm::laplacian(DT, T) ); // this is line 78 and error of mis match of dimension came in this transport equation. I am not understanding why this is so ? Therefore I asked units of phi. Actually by definition phi is U. So there should not be any dimension problem. incompatible dimensions for operation [T[0 0 -1 1 0 0 0] ] + [T[1 -3 -1 1 0 0 0] ddt[T] : [0 0 -1 1 0 0 0] But how, div(phi, T) : [1 -3 -1 1 0 0 0] if phi is U ?? It seems that phi has dimension of [1 -2 -1 0 0 0 0] which is density*velocity !!!(not as definition of phi !!) I tried to write U instead of phi but then it gave syntax error because U is vector: buoyantTransportSimpleFoamNew.C:76: erreur: no matching function for call to ‘div(Foam::volVectorField&, Foam::volScalarField&)’ Please help regarding this. I would really be thankful to you. JM |
May 17, 2009, 09:06 |
#24 |
Hi JM
I think there should be a problem in your parameter DT demension. It should be divided by a rho dimension. Just like relation between dynamic viscosity and kinetic viscosity. Junwei |
May 17, 2009, 09:14 |
#25 |
Jagmohan Meena
Rep Power: 16 |
[T[0 0 -1 1 0 0 0] ] + [T[1 -3 -1 1 0 0 0] As there is + sign between then ..problem is with dimensions of phi. I have checked dimensions of DT they are suitable for transport equation. However, I multiplied phi term by 1/rho and it worked. But at 10th iteration it gave error: Time = 0.009 DILUPBiCG: Solving for Ux, Initial residual = 0.296946, Final residual = 9.82349e-07, No Iterations 4 DILUPBiCG: Solving for Uy, Initial residual = 0.722249, Final residual = 5.61724e-06, No Iterations 4 DILUPBiCG: Solving for Uz, Initial residual = 0.666469, Final residual = 5.15711e-06, No Iterations 4 DICPCG: Solving for pd, Initial residual = 0.910202, Final residual = 0.022805, No Iterations 1001 time step continuity errors : sum local = 6.76243e+10, global = 2.96929e+07, cumulative = 2.96929e+07 rho max/min : 1.68757e+13 -3.65665e+15 DILUPBiCG: Solving for T, Initial residual = 0.889206, Final residual = 424.999, No Iterations 1001 DILUPBiCG: Solving for W, Initial residual = 6.48371e-05, Final residual = 0.000274964, No Iterations 1001 #0 Foam::error:rintStack(Foam::Ostream&) in "/usr/lib/OpenFOAM-1.5/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/usr/lib/OpenFOAM-1.5/lib/libOpenFOAM.so" #2 ?? in "/lib/libc.so.6" #3 Foam:ILUPreconditioner::calcReciprocalD(Foam::Fi eld<double>&, Foam::lduMatrix const&) in "/usr/lib/OpenFOAM-1.5/lib/libOpenFOAM.so" #4 Foam:ILUPreconditioner:ILUPreconditioner(Foam: :lduMatrix::solver const&, Foam::Istream&) in "/usr/lib/OpenFOAM-1.5/lib/libOpenFOAM.so" #5 Foam::lduMatrix:reconditioner::addasymMatrixCons tructorToTable<Foam:ILUPreconditioner>::New(Foam ::lduMatrix::solver const&, Foam::Istream&) in "/usr/lib/OpenFOAM-1.5/lib/libOpenFOAM.so" #6 Foam::lduMatrix:reconditioner::New(Foam::lduMatr ix::solver const&, Foam::Istream&) in "/usr/lib/OpenFOAM-1.5/lib/libOpenFOAM.so" #7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/usr/lib/OpenFOAM-1.5/lib/libOpenFOAM.so" #8 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/usr/lib/OpenFOAM-1.5/lib/libfiniteVolume.so" #9 Foam::lduMatrix::solverPerformance Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&) in "/home/users/jagmohan//OpenFOAM/jagmohan-1.5/applications/bin/buoyantTransportSimpleFoam" #10 Foam::compressible::RASModels::kEpsilon::correct() in "/usr/lib/OpenFOAM-1.5/lib/libcompressibleRASModels.so" #11 main in "/home/users/jagmohan//OpenFOAM/jagmohan-1.5/applications/bin/buoyantTransportSimpleFoam" #12 __libc_start_main in "/lib/libc.so.6" #13 _start in "/home/users/jagmohan//OpenFOAM/jagmohan-1.5/applications/bin/buoyantTransportSimpleFoam" Exception en point flottant jagmohan@biquad:/home/users/jagmohan/OpenFOAM/jagmohan-1.5/run/coude_diffusion_thermal$ Now struggling with this. If you have any idea to remove this kind of computational error then please put your views. Anyways discussion really helped me a lot to reach at this level. Thank you very much !! JM |
May 17, 2009, 09:21 |
#26 |
Hi JM
your simulation diverged. this can be caused by many many reasons. If the solver was correctly written, bad boundary settings may be the primary problems. Junwei |
May 17, 2009, 10:15 |
#27 |
Jagmohan Meena
Rep Power: 16 |
Can you comment on how rho is defined in buoyantSimpleFoam in creatField file ? It is defined as :
volScalarField rho ( IOobject ( "rho", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), thermo->rho() ); I don't understand why it is defined as No Read and No Write. And where is the value of rho defined. I am unable to find it in code or case !! In addition can you tell me what rho max/min value shows during computation. It keeps changing but I think it should not change !!! Please comment on this ! Thank you very much !! JM |
May 17, 2009, 11:38 |
#28 |
Hi JM
BuoyantSimpleFoam is a compressible solver. Temperature difference incurs density difference and following fluid flow. The density will change, and it is a main driven force for fliud flow. rho is obtain from basicThermo class, and update rho every time step. See the pEqn.H:51. Junwei |
May 18, 2009, 03:54 |
#29 |
Jagmohan Meena
Rep Power: 16 |
okay !!
Thank you very much for your valuable time. |
November 25, 2011, 05:26 |
#30 |
Claus Meister
Rep Power: 17 |
Hello Fomers,
does anybody know why non-orthogonal steps must be performed. I do not understand the algorithm in this way. |
ScalarTransportFoam and turbulent diffusion coefficient | rybakov2 | OpenFOAM Running, Solving & CFD | 2 | June 24, 2014 14:21 |
