Axisymmetric
Old   December 11, 2007, 10:36
Default hi everybody i would like t
rengu
hi everybody
i would like to create an axi-symmetric case
i have create my 3d mesh with the 5° with the mesh generator Salome.
i have create group of faces for the boundaries(2 wedge,wall,inlet,outlet....) and groups of edge for the axis
I export it to unv format
When i do the conversion to OF format
it recognize the face group but not the edge group
how can i do to have my boundary axis in OpenFOAM?
best regards
Old   December 11, 2007, 11:07
Default Hi, This can help you http:/
Rachid bannari
bannari is on a distinguished road
This can help you
http://openfoamwiki.net/index.php/Contrib_MakeAxialMesh
Best regards
bannari is offline   Reply With Quote
Old   December 12, 2007, 08:19
Default hi i have follow http://op
rengu
hi
i have follow http://openfoamwiki.net/index.php/Contrib_MakeAxialMesh
but i 've got this error
~/> makeAxialMesh /home/gui/Desktop/ plan axe frontback
Create mesh for time = 0
Plane of the grid: (0 0 1) (52.5 -122 2.5)
The rotation-axis: ((0 0 2.5) (0 -220 2.5))
Creating wedge with an opening angle of 5 degrees
Radius to axis: min = 2.5 max = 105.03
Splitting patch frontback
Copying patches
Creating Patches
Creating Pos-patch
Creating Neg-patch
Changing patches
--> FOAM FATAL ERROR : Cannot change patches after having changed faces.
Please call changePatches first.
From function repatchPolyTopoChanger::changePatches(const List<polypatch*>&)
in file polyTopoChange/repatchPolyTopoChanger/repatchPolyTopoChanger.C at line 72.
To change the patch is not the aim of the make AxialMESH?i've got to change the patch first?
best regards
Old   December 12, 2007, 13:38
Default You're using it on a 1.4+-inst
Assistant Moderator
Bernhard Gschaider
You're using it on a 1.4+-installation? I'm surprised that the sources (which were written for 1.3) compile on that. Some of the underlying semantics changed as Mattijs pointed out to me. I will fix that and publish a new version (hopefully next week)
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 28, 2007, 10:22
Default Hi All, I modified Bernhard's
David P. Schmidt
schmidt_d is on a distinguished road
Hi All,
I modified Bernhard's 1.3 version of make axial mesh so that it works with 1.4 and 1.4.1. It probably could have been done better, but here is what I did:
Since OF 1.4 and later, you must have the axisymmetric domain centered on the z=0 plane. The 1.3 version of makeAxialMesh made a copy of the 2D mesh that is rotated by five degrees. My change is to make the copy so that it is rotated from the xy plane by +2.5 degrees and then rotate the original by -2.5 degrees. You still get a 5 deg. wedge.
See the update at:
It has worked for me. However, RENAUD Guillaume above, may still have problems. I don't see what causes his error.
-David Schmidt
schmidt_d is offline   Reply With Quote
Old   January 1, 2008, 13:50
Default Extending the definition of "n
Assistant Moderator
Bernhard Gschaider
Extending the definition of "next week" (see above) to "next year" I managed to clean up my internal versiion, incorporate David's suggestions and put it on of-extend (see http://openfoamwiki.net/index.php/Contrib_MakeAxialMesh )
Bernhard
Old   January 31, 2008, 16:46
Default When changing to the OF 1.4.1
David P. Schmidt
When changing to the OF 1.4.1 hosted on the Subversion site (the tagged version that is the OpenCFD release of 1.4.1 plus bug fixes) I encountered the same error message that Renaud encountered. I took the error message at face value and modified the makeAxialMesh code to call changePatches first. All seems well and the latest code is listed as the 1.4.1 version on
Old   April 26, 2008, 13:29
Default Hi all! I don't understand ho
Simone.Sa
bonzodeb is on a distinguished road
Hi all!
I don't understand how collapseEdges work.
I use makeAxialMesh without errors.
At the end it says that I must use collapseEdges to clean the grid.
collapseEdges expected 4 arguments
<edge> is refers to which edge lenght??The edge of the axial patch that have zero area??
<merge> angle of what??
Can somebody help me or give me a link that can help me??
For example in my case the blockMesh before makeAxialeMesh is that:
convertToMeters 1;
vertices
(0 0 -0.05)
(100 0 -0.05)
(100 0.5 -0.05)
(0 0.5 -0.05)
(0 0 0.05)
(100 0 0.05)
(100 0.5 0.05)
(0 0.5 0.05)
blocks
hex (0 1 2 3 4 5 6 7) (100 10 1) simpleGrading (1 1 1)
edges
patches
patch inlet
(0 4 7 3)
patch outlet
(2 6 5 1)
wall pipe
(3 7 6 2)
empty axis
(1 5 4 0)
empty frontAndBack
(0 3 2 1)
(4 5 6 7)
mergePatchPairs
what edge lenght and merge angle can I use in collapseEdges utility?
Simone
bonzodeb is offline   Reply With Quote
Axisymmetric FEM Help Jesus Rojo Main CFD Forum 1 May 6, 2016 06:14
Abt: Axisymmetric B.C. jinwon park Main CFD Forum 0 March 10, 2008 14:03
From 2D to axisymmetric Nestor FLUENT 0 February 3, 2008 12:33
2D v.s. Axisymmetric Atit FLUENT 0 August 20, 2007 14:29
axisymmetric in vof moona FLUENT 1 January 25, 2007 08:49
