MRFZone
Old   April 22, 2008, 10:55
Default Is it possible to get access t
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Is it possible to get access to the private variable "dict_" in a smart way? The only idea that I have is to rewrite the classes MRFZone and MRFZones...which is not very smart
Or how can I read the constant/MRFZones file into an IOdictionary? If I try the classic way:
IOdictionary mrfDict
<blockquote>IOobject
<blockquote>"MRFZones",
runTime.constant(),
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
)</blockquote>
const wordList mrfPatches = mrfDict.lookup("patches");</blockquote>
I get an error saying that "patches" is not found in the MRFZones file.
Any suggestions?
Dragos
dmoroian is offline   Reply With Quote
Old   April 23, 2008, 04:59
Default Hi Dragos Is it just the "p
jaswi is on a distinguished road
Hi Dragos
Is it just the "patches" for which you are getting the error. Did you try reading in the other variables such as origin, axis etc.
Another option can be adding a member function to the MRFZone class which will returns you the dict_ variable.
Regards
Jaswi
jaswi is offline   Reply With Quote
Old   April 23, 2008, 05:20
Default Hi Jaswi, I didn't try to loo
dmoroian's Avatar
Dragos
Hi Jaswi,
I didn't try to lookup for origin or axis because I didn't believe they will work if finding patches didn't work.
As a work around I wrote a new set of MRFZone*.{H,C} with a public member function that returns the requested variables (see on wiki: computeTorq). But as I said also above this is not an elegant solution.
Dragos
