TimeVaryingNonuniformFixedValue
Old   April 15, 2008, 08:50
Default Hi All, I tried installing
Nishant
nishant_hull is on a distinguished road
Hi All,
I tried installing and recompiling your timeVaryingNonuniformFixedValue patch with my OF-1.4.1 installation. But unfortunately I found some error while recompiling it. Can you tell me, what's going wrong?
The error reported is:
lnInclude/fixedValueFvPatchField.C:41: note: Foam::fixedValueFvPatchField<type>::fixedValueFvPa tchField(const Foam::fvPatch&, const Foam::DimensionedField<type,>&) [with Type = double]
make: *** [Make/linuxGccDPOpt/timeVaryingNonuniformFixedValueFvPatchFields.o] Error 1
regards,
Nishant
Thanks and regards,
Nishant
nishant_hull is offline   Reply With Quote
Old   July 1, 2009, 10:38
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Is this tool going to work with OpenFOAM 1.5?
The file structure of http://openfoamwiki.net/images/d/db/...FixedValue.tgz is not the same as with the current release...
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   July 2, 2009, 02:30
norman1981's Avatar
Norman Del Puppo
norman1981 is on a distinguished road
I used the OpenFOAM-1.5.x for some time and a full working version of the timeVaryingUniformFixedValue was already included in the source packages, therefore I think you could avoid the porting of an old version ;-)
Regards
Norman
norman1981 is offline   Reply With Quote
Old   July 2, 2009, 03:01
sega's Avatar
Sebastian Gatzka
Originally Posted by norman1981 View Post
Regards
Norman
Yes, of course. But I am talking about the NONUNIFORM version ...
Old   July 2, 2009, 04:39
norman1981's Avatar
Norman Del Puppo
I'm sorry,
you are right, I misread your post.
Regards
Norman
Old   July 2, 2009, 05:05
sega's Avatar
Sebastian Gatzka
No problem. Am I guessing right, that groovyBC is the current 'state of the art' to handle such problems?
Old   July 2, 2009, 06:30
norman1981's Avatar
Norman Del Puppo
I think it could be a good choice, it is really versatile to accomplish many different tasks and it is easy to set-up (the contrib web page also contains many examples).
Norman
Old   July 2, 2009, 07:15
Assistant Moderator
Bernhard Gschaider
Depends (not sure what the timeVaryingNonuniform actually does). The time-dependence can be read from a file but for the spatial dependence currently only analytical expressions are possible (no reading of velocity profiles from files) only "analytical" expressions
