Permeability filling of container outlet condition
Old   March 28, 2008, 09:01
Default Can you attach your code?
  #21
Billy
billy is on a distinguished road
billy is offline   Reply With Quote
Old   June 2, 2014, 12:21
Default selective outlet BC
  #22
Peter
John Degenkolb is on a distinguished road
Hi Foamers,
I'm trying to redo the boundary condition that Francesco created.
I copied and renamed the inletOutletFvPatchField boundary conditions to vapMembraneFvPatchField and tried costumize them.
My .C is:
#include "vapMembraneFvPatchField.H"
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
template<class Type>
Foam::vapMembraneFvPatchField<Type>::vapMembraneFvPatchField
    const fvPatch& p,
    const DimensionedField<Type, volMesh>& iF,
    const volScalarField& alphaMatrix
    mixedFvPatchField<Type>(p, iF),
  // original: phiName_("phi")
    alphaMatrixName_("alphaMatrix")
    this->refValue() = pTraits<Type>::zero;
    this->refGrad() = pTraits<Type>::zero;
    this->valueFraction() = 0.0;
    const vapMembraneFvPatchField<Type>& ptf,
    const fvPatch& p,
    const fvPatchFieldMapper& mapper
    mixedFvPatchField<Type>(ptf, p, iF, mapper),
    phiName_(ptf.phiName_)
    const fvPatch& p,
    const dictionary& dict
    phiName_(dict.lookupOrDefault<word>("phi", "phi"))
    this->refValue() = Field<Type>("inletValue", dict, p.size());
    if (dict.found("value"))
        fvPatchField<Type>::operator=
            Field<Type>("value", dict, p.size())
    else
        fvPatchField<Type>::operator=(this->refValue());
    mixedFvPatchField<Type>(ptf),
    mixedFvPatchField<Type>(ptf, iF),
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
void Foam::vapMembraneFvPatchField<Type>::updateCoeffs()
    if (this->updated())
        return;
    const Field<scalar>& alphaMatrix =
        this->patch().template lookupPatchField<surfaceScalarField, scalar>
            alphaMatrixName_
    this->valueFraction() = 1.0 - alphaMatrix();
    mixedFvPatchField<Type>::updateCoeffs();
void Foam::vapMembraneFvPatchField<Type>::write(Ostream& os) const
    fvPatchField<Type>::write(os);
    if (phiName_ != "phi")
        os.writeKeyword("phi") << phiName_ << token::END_STATEMENT << nl;
    this->refValue().writeEntry("inletValue", os);
    this->writeEntry("value", os);
// * * * * * * * * * * * * * * * Member Operators  * * * * * * * * * * * * * //
void Foam::vapMembraneFvPatchField<Type>::operator=
    const fvPatchField<Type>& ptf
        this->valueFraction()*this->refValue()
        + (1 - this->valueFraction())*ptf
And my .H file:
#ifndef vapMembraneFvPatchField_H
#define vapMembraneFvPatchField_H
#include "mixedFvPatchField.H"
namespace Foam
                   Class vapMembraneFvPatchField Declaration
class vapMembraneFvPatchField
    public mixedFvPatchField<Type>
protected:
    // Protected data
        //- Name of flux field
        word phiName_;
            //- Name of the volume fraction field
            word alphaMatrixName_;
        // by me, to avoid " class doesn not have any diled name "gamma_"
        word gamma_;
public:
    //- Runtime type information
    TypeName("vapMembrane");
    // Constructors
        //- Construct from patch and internal field
            const fvPatch&,
            const DimensionedField<Type, volMesh>&,
        //- Construct from patch, internal field and dictionary
            const fvPatch&,
            const dictionary&
        //- Construct by mapping given vapMembraneFvPatchField onto a new patch
            const vapMembraneFvPatchField<Type>&,
            const fvPatch&,
        //- Construct as copy
        //- Construct and return a clone
        virtual tmp<fvPatchField<Type> > clone() const
            return tmp<fvPatchField<Type> >
                new vapMembraneFvPatchField<Type>(*this)
        //- Construct as copy setting internal field reference
        //- Construct and return a clone setting internal field reference
        ) const
                new vapMembraneFvPatchField<Type>(*this, iF)
    // Member functions
        //- Update the coefficients associated with the patch field
        virtual void updateCoeffs();
        //- Write
        virtual void write(Ostream&) const;
    // Member operators
        virtual void operator=(const fvPatchField<Type>& pvf);
} // End namespace Foam
#ifdef NoRepository
#   include "vapMembraneFvPatchField.C"
#endif
#endif
When I try to do wclean; wmake I get the following error:
peter@peter-HP-Compaq-nw8440-RZ646EC-ABD:~/OpenFOAM/peter-2.3.0/mySolvers/vapMembrane$ wclean; wmake
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file vapMembrane/vapMembraneFvPatchFields.C
SOURCE=vapMembrane/vapMembraneFvPatchFields.C ;  g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam230/src/triSurface/lnInclude -I/opt/openfoam230/src/meshTools/lnInclude -I/opt/openfoam230/src/transportModels/twoPhaseMixture/lnInclude -I/opt/openfoam230/src/transportModels/incompressible/lnInclude -I/opt/openfoam230/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam230/src/finiteVolume/lnInclude -I/opt/openfoam230/src/meshTools/lnInclude -I/opt/openfoam230/src/fvOptions/lnInclude -I/opt/openfoam230/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linuxGccDPOpt/vapMembraneFvPatchFields.o
In file included from vapMembrane/vapMembraneFvPatchField.H:195:0,
                 from vapMembrane/vapMembraneFvPatchFields.H:29,
                 from vapMembrane/vapMembraneFvPatchFields.C:28:
vapMembrane/vapMembraneFvPatchField.C: In member function ‘virtual void Foam::vapMembraneFvPatchField<Type>::updateCoeffs()’:
vapMembrane/vapMembraneFvPatchField.C:133:47: error: no match for call to ‘(const Foam::Field<double>) ()’
In file included from /opt/openfoam230/src/OpenFOAM/lnInclude/token.H:49:0,
                 from /opt/openfoam230/src/OpenFOAM/lnInclude/UListIO.C:28,
                 from /opt/openfoam230/src/OpenFOAM/lnInclude/UList.C:239,
                 from /opt/openfoam230/src/OpenFOAM/lnInclude/UList.H:473,
                 from /opt/openfoam230/src/OpenFOAM/lnInclude/List.H:43,
                 from /opt/openfoam230/src/OpenFOAM/lnInclude/fileNameList.H:42,
                 from /opt/openfoam230/src/OpenFOAM/lnInclude/OSspecific.H:39,
                 from /opt/openfoam230/src/OpenFOAM/lnInclude/regIOobject.H:43,
                 from /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricField.H:42,
                 from /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricScalarField.H:38,
                 from /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricFields.H:34,
                 from /opt/openfoam230/src/finiteVolume/lnInclude/volFields.H:37,
                 from vapMembrane/vapMembraneFvPatchFields.C:26:
/opt/openfoam230/src/finiteVolume/lnInclude/fvPatchField.H: In instantiation of ‘static Foam::tmp<Foam::fvPatchField<Type> > Foam::fvPatchField<Type>::addpatchConstructorToTable<fvPatchFieldType>::New(const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&) [with fvPatchFieldType = Foam::vapMembraneFvPatchField<double>; Type = double]’:
/opt/openfoam230/src/finiteVolume/lnInclude/fvPatchField.H:120:9:   required from ‘Foam::fvPatchField<Type>::addpatchConstructorToTable<fvPatchFieldType>::addpatchConstructorToTable(const Foam::word&) [with fvPatchFieldType = Foam::vapMembraneFvPatchField<double>; Type = double]’
vapMembrane/vapMembraneFvPatchFields.C:38:1:   required from here
/opt/openfoam230/src/OpenFOAM/lnInclude/runTimeSelectionTables.H:76:66: error: no matching function for call to ‘Foam::vapMembraneFvPatchField<double>::vapMembraneFvPatchField(const Foam::fvPatch&, const Foam::DimensionedField<double, Foam::volMesh>&)’
             return autoPtr< baseType >(new baseType##Type parList);           \
/opt/openfoam230/src/finiteVolume/lnInclude/fvPatchField.H:120:9: note: in expansion of macro ‘declareRunTimeSelectionTable’
/opt/openfoam230/src/OpenFOAM/lnInclude/runTimeSelectionTables.H:76:66: note: candidates are:
vapMembrane/vapMembraneFvPatchField.C:105:1: note: Foam::vapMembraneFvPatchField<Type>::vapMembraneFvPatchField(const Foam::vapMembraneFvPatchField<Type>&, const Foam::DimensionedField<Type, Foam::volMesh>&) [with Type = double]
vapMembrane/vapMembraneFvPatchField.C:105:1: note:   no known conversion for argument 1 from ‘const Foam::fvPatch’ to ‘const Foam::vapMembraneFvPatchField<double>&’
vapMembrane/vapMembraneFvPatchField.C:94:1: note: Foam::vapMembraneFvPatchField<Type>::vapMembraneFvPatchField(const Foam::vapMembraneFvPatchField<Type>&) [with Type = double]
vapMembrane/vapMembraneFvPatchField.C:94:1: note:   candidate expects 1 argument, 2 provided
vapMembrane/vapMembraneFvPatchField.C:50:1: note: Foam::vapMembraneFvPatchField<Type>::vapMembraneFvPatchField(const Foam::vapMembraneFvPatchField<Type>&, const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&, const Foam::fvPatchFieldMapper&) [with Type = double]
vapMembrane/vapMembraneFvPatchField.C:50:1: note:   candidate expects 4 arguments, 2 provided
vapMembrane/vapMembraneFvPatchField.C:64:1: note: Foam::vapMembraneFvPatchField<Type>::vapMembraneFvPatchField(const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&, const Foam::dictionary&) [with Type = double]
vapMembrane/vapMembraneFvPatchField.C:64:1: note:   candidate expects 3 arguments, 2 provided
vapMembrane/vapMembraneFvPatchField.C:31:1: note: Foam::vapMembraneFvPatchField<Type>::vapMembraneFvPatchField(const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&, const volScalarField&) [with Type = double; Foam::volScalarField = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>]
vapMembrane/vapMembraneFvPatchField.C:31:1: note:   candidate expects 3 arguments, 2 provided
I just pasted the first of the error message.
It seems that alphaMatrix, which should contain the volume fraction of liquid polymer, is not accessible. I'm running openfoam 2.3.0. Please find in attachment my alpha.matrix file which defines the volume fractions of liquid at t=0.
Thank you in advance for your help.
Peter
John Degenkolb is offline   Reply With Quote
outlet boundary condition Arman FLUENT 2 September 22, 2007 13:08
how to set boundary condition for a tank filling w namrata FLUENT 6 May 2, 2007 10:23
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 08:07
outlet condition in SEM Anis Phoenics 0 May 5, 2006 09:38
outlet Boundary condition Tol na Deen CFX 2 July 23, 2002 08:49
