No residual control data found
Old   November 19, 2020, 01:04
Default No residual control data found
CH VINOD KUMAR REDDY
vinod956 is on a distinguished road
Hi friends,
I am very new to Openfoam. I copied a tutorial from combustion XiFoam then modified its geometry as per my project. After that I had run blockMesh. It was successful and polymesh was created. Then tried to run XiFoam solver on it and ended up with the error that no residual control data found. This is how it is shown
| \\ / O peration | Version: v2006 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _b45f8f6f58-20200629 OPENFOAM=2006
Arch : "LSB;label=32;scalar=64"
Exec : XiFoam
Date : Nov 19 2020
Time : 11:21:17
Host : LAPTOP-PE3G8S0K
PID : 434
I/O : uncollated
Case : /home/chitti/OpenFOAM_files/sim3b
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
Reading combustion properties
Found ignition cells:
14
0
1
2
40
41
42
80
81
82
120
121
160
161
200
Ignition on
Reading thermophysical properties
Selecting thermodynamics package
type heheuPsiThermo;
mixture homogeneousMixture;
transport const;
thermo janaf;
equationOfState perfectGas;
specie specie;
energy absoluteEnthalpy;
min(b) = 1
Reading field U
Creating turbulence model
Selecting turbulence model type RAS
Selecting RAS turbulence model LaunderSharmaKE
RAS
RASModel LaunderSharmaKE;
turbulence on;
printCoeffs on;
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 0;
sigmak 1;
sigmaEps 1.3;
Creating field Xi
Creating the unstrained laminar flame speed
Selecting laminar flame speed correlation Gulders
Reading strained laminar flame speed field Su
Calculating turbulent flame speed field St
Creating field dpdt
Creating field kinetic energy K
No MRF models present
No finite volume options present
Courant Number mean: 0 max: 0
Starting time loop
Time = 5e-06
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
PIMPLE: iteration 1
DILUPBiCGStab: Solving for Uy, Initial residual = 0.999996, Final residual = 0.000344645, No Iterations 1
Max St-Courant Number = 0.00432165
Igniting cell 0 state : 1 1 0.434 1e-15
Igniting cell 1 state : 1 1 0.434 1e-15
Igniting cell 2 state : 1 1 0.434 1e-15
Igniting cell 40 state : 1 1 0.434 1e-15
Igniting cell 41 state : 1 1 0.434 1e-15
Igniting cell 42 state : 1 1 0.434 1e-15
Igniting cell 80 state : 1 1 0.434 1e-15
Igniting cell 81 state : 1 1 0.434 1e-15
Igniting cell 82 state : 1 1 0.434 1e-15
Igniting cell 120 state : 1 1 0.434 1e-15
Igniting cell 121 state : 1 1 0.434 1e-15
Igniting cell 160 state : 1 1 0.434 4.24516e-13
Igniting cell 161 state : 1 1 0.434 1e-15
Igniting cell 200 state : 1 1 0.434 4.24516e-13
DILUPBiCGStab: Solving for b, Initial residual = 1, Final residual = 0.000382049, No Iterations 1
min(b) = 0.985393
I am also pasting my fvsolution file here
solvers
"(p|rho)"
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0.1;
"(p|rho)Final"
$p;
tolerance 1e-06;
relTol 0;
"(U|b|Su|Xi|ha|hau|k|epsilon)"
solver PBiCGStab;
preconditioner DILU;
tolerance 1e-05;
relTol 0.1;
"(U|b|Su|Xi|ha|hau|k|epsilon)Final"
solver PBiCGStab;
tolerance 1e-05;
relTol 0;
PIMPLE
nOuterCorrectors 2;
nCorrectors 1;
nNonOrthogonalCorrectors 0;
Can someone please help me in finding the error
vinod956 is offline   Reply With Quote
Old   November 19, 2020, 02:23
Troy Snyder
tas38 is on a distinguished road
You are missing a residual control block from within the PIMPLE block. You need something like the following if you plan to set "nOuterCorrectors" to a large value
PIMPLE
    nOuterCorrectors    50;
    nCorrectors       2;
    residualControl
        U
                tolerance  1e-6;
                relTol      0;
        p
                tolerance  1e-6;
                relTol      0;
    relaxationFactors
        fields
              p        0.3;
              pFinal   1;
        equations
              "U|k|epsilon"          0.3;
              "(U|k|epsilon)Final"   1;
} // END PIMPLE
tas38 is offline   Reply With Quote
Old   November 19, 2020, 02:43
PIMPLE
    nCorrectors       2;
    residualControl
        U
                tolerance  1e-6;
                relTol      0;
        p
                tolerance  1e-6;
                relTol      0;
    relaxationFactors
        fields
              p        0.3;
              pFinal   1;
        equations
              "U|k|epsilon"          0.3;
} // END PIMPLE
Thank you for your reply. I will try
Old   November 19, 2020, 04:01
Yann
Yann will become famous soon enough
This message is not an error:
It is just here to tell you there is no residual control defined, hence the solver will just run for 2 loops no matter what is the residual.
AFAIK this is not a problem. If the solver crashes this is certainly not because you did not define the residual controls. The problem is somewhere else.
Regards,
Yann
Yann is offline   Reply With Quote
Old   November 19, 2020, 07:57
Regards,
Yann
Thanks for your reply
Can u please figure out where the problem is?
Old   November 19, 2020, 08:31
Yann
I cannot really help, I have never used XiFoam and there is no error displayed in the log on your first post.
Is there anything else written in your terminal when you run the solver?
Yann
Old   November 19, 2020, 20:19
Yann
The problem is iterations are not running.
Do you know how to run iterations.
Old   November 20, 2020, 03:13
Yann
Does the solver just hang forever?
Can you post a full log of your run?
I have no experience with XiFoam so if the solver is just hanging I am not sure I can help you. Maybe XiFoam users can help.
Regards,
Yann
Old   November 20, 2020, 22:08
Regards,
Yann
chitti@LAPTOP-PE3G8S0K:~/OpenFOAM_files/sim3b$ XiFoam
Exec : XiFoam
Date : Nov 21 2020
Time : 08:33:11
PID : 473
I/O : uncollated
nProcs : 1
Create time
14
0
1
2
40
41
42
80
81
82
120
121
160
161
200
Ignition on
transport const;
thermo janaf;
specie specie;
min(b) = 1
Reading field U
RAS
turbulence on;
printCoeffs on;
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 0;
sigmak 1;
sigmaEps 1.3;
Creating field Xi
Creating field dpdt
Starting time loop
Time = 5e-06
PIMPLE: iteration 1
min(b) = 0.985393
This is the full log of my run. it is not hanging.
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 02:42
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 18:17
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
