A question about the residuals
Old   March 13, 2008, 12:06
Default Hi to all, I have a stupid qu
matteo_gautero
Hi to all,
I have a stupid question about the residuals that are printed by OF during the simulation. When I used Fluent, there was a window where the residuals of the equation involved in the simulation were plotted. In OF there are two kind of residuals, "initial residual" and "final residual"... which of these is the equivalent residuals of Fluent plot?
Sorry for my stupid question, but I have this doubt...
Thanks in advance,
Matteo.
Old   March 14, 2008, 03:54
Default i dont have any experience wit
Laurence Griffiths
lgriffiths is on a distinguished road
i dont have any experience with fluent, and quite new to foam too - but as i understood it the 'normal' residual is the one before the iteration.
the initial represents how your actual solution is progressing... if that makes sense - your 'final' residual is probably set to some criteria in fvSolutions file.
... i hope thats right
lgriffiths is offline   Reply With Quote
Old   March 14, 2008, 05:58
Default Hi Laurence, thanks for your
matteo_gautero
Hi Laurence,
thanks for your response. I asked this because my friend told me that the correspondent residual of Fluent in OF is the first ("initial residual") and I'm not sure of this.
Matteo.
Old   March 14, 2008, 09:41
Default yes, using the final resid
Laurence Griffiths
yes,
using the final residual to check the convergence of your solution wouldnt really make sense - if you check the fvSolutions file, your final residual should be converging too (or less than) the tolerances defined for the respective matrix solvers (hence wont give the standard 'convergence' curves).
the initial residual, will be your residual between your time steps - so your friend is correct if this is what fluent is plotting.
Residuals maka OpenFOAM Bugs 0 August 4, 2008 14:07
Residuals cristiano FLUENT 1 March 28, 2008 16:00
residuals Siddharth Khowala FLUENT 1 June 8, 2006 03:41
Easy question about residuals Freeman FLUENT 2 February 26, 2006 23:03
Residuals? Tom Main CFD Forum 6 November 28, 2002 04:09
