About phi in icoFoam
Like Tree4Likes
  • 4 Post By schmidt_d
Old   February 18, 2008, 15:59
Default Hi! U = rUA*UEqn.H(); phi
kar
Kārlis Repsons
kar is on a distinguished road
Hi!
U = rUA*UEqn.H();
phi = (fvc::interpolate(U) & mesh.Sf())
+ fvc::ddtPhiCorr(rUA, U, phi);
What fvc::ddtPhiCorr(rUA, U, phi) is there for?
if (nonOrth == nNonOrthCorr)
phi -= pEqn.flux();
And what ".flux()" is returning?
Kārlis
kar is offline   Reply With Quote
Old   February 19, 2008, 12:47
Default Karlis, The .flux() method
David P. Schmidt
schmidt_d is on a distinguished road
Karlis,
The .flux() method takes the face fluxes that come from the off-diagonal terms of the equation, in this case pEqn, and returns them directly. An easier-to-understand example would be if I were doing the continuity equation, where rhoEqn is:
fvm::ddt(rho) + fvc::div(phiv,rho)
where phiv is the velocity interpolated to cell faces and dotted with the face normals.
after solving, rhoEqn.flux() would give you the mass flux out of each cell face. Similarly, pEqn.flux() gives you the momentum flux due to the fvm:: terms of the pressure equation.
-DPS
ps. The ddtPhiCorr is a mysterious term that attempts to correct for temporal error in the flux...can't help you there.
schmidt_d is offline   Reply With Quote
Old   February 19, 2008, 13:21
Default Good evening David! >.flux(
kar
Kārlis Repsons
Good evening David!
Why it's necessary to distinguish between matrix diagonal and off-diagonal elements?
What papers and www would you suggest to understand this kind of things?
K.
Old   February 20, 2008, 05:20
Default Hi Karlis Matrix diagonal e
jaswi is on a distinguished road
Hi Karlis
Matrix diagonal elements are the elements for which you are seeking solution and off-diagonal elements are those which will effect this solution.
Checkout the basic Finite Volume, SIMPLE, PISO formulations in this book:
1) An Introduction to CFD: The Finite Volume Method by Versteeg, Malalasekera.
2) CFD by Anderson
With Best Regards
Jaswi
jaswi is offline   Reply With Quote
IcoFoam aap OpenFOAM Running, Solving & CFD 15 May 28, 2012 08:30
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
Possible bug in icoFoam msrinath80 OpenFOAM Bugs 6 November 19, 2007 17:35
IcoFoam on AIX 53 ds2taieb OpenFOAM Installation 1 March 24, 2006 03:22
