How to specify BCs to solve a Poiseuille flow
Old   February 11, 2008, 14:01
Default Hello, I was trying to solv
kar
Kārlis Repsons
kar is on a distinguished road
I was trying to solve a parabolic flow in 2D square-like domain.
* In blockMeshDict and boundary file I specified just "patch" for inlet and outlet,
* In /0/U I set zeroGradient on in/out, (0 0 0) on walls + empty
* In /0/p I set fixedValue on in/out, zeroGradient on walls + empty.
But.... solution obviously diverge. Aren't those BCs sufficent to describe a problem?
I think, I don't understand how to set BCs in OpenFOAM, for example - why should I use physicalType? Maybe you can advice something useful at least for that poiseuille flow?
kar is offline   Reply With Quote
Old   February 11, 2008, 14:55
Default Oh, I see a parabolic velocity
kar
Kārlis Repsons
Oh, I see a parabolic velocity distribution now and it feels so good! The problem was - I forgot to take into account a fact, that for icoFoam pressure must be divided by density. So I tried to solve for 1000 times greater pressure!
Maybe I'll see somewhere else why physicalType should be specified...
Old   February 11, 2008, 16:14
Default I checked solution more carefu
kar
Kārlis Repsons
I checked solution more carefully and .. trouble doesn't stop - I have almost exactly 2x greater U values comparing with analytical!
So in SI:
nu = 1e-4,
geometry: dx=0.01, dy=0.1, dz=0.001,
flow is in y direction,
delta p = 0.016 (divided by ro)
According to wikipedia, Umax = 0.01. But solution gives 0.02!! How come?
Old   February 11, 2008, 17:12
Default Hi Karlis The Poiseuille-fl
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Karlis
The Poiseuille-flow I could find on wiki (please add link in the future), was for a circular pipe flow. Your setup is for a 2D case, i.e. Poiseuille flow between two flat plates. The ratio between u_max in these two cases is exactly a factor of 2.
/ Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   February 12, 2008, 03:07
Default Thank you, Niels! I was think
kar
Kārlis Repsons
Thank you, Niels!
I was thinking in a quick way - take a plane of cylinder and calculate for it.. Actually different problem is solved in such way.
Incompressible laminar poiseuille flow samarth OpenFOAM Running, Solving & CFD 20 July 13, 2010 03:38
Basic Poiseuille flow simulation question Ashish Main CFD Forum 0 October 2, 2007 13:05
Poiseuille flow Kirikou Main CFD Forum 0 November 23, 2006 13:32
Simple Poiseuille flow Maggie CFX 0 May 27, 2004 10:58
Poiseuille flow problem Rosie FLUENT 1 December 6, 2002 16:52
