February 9, 2008, 02:15 |
It is said on ferziger's book,
Daniel WEI (老魏)
Rep Power: 21 |
It is said on ferziger's book, that Courant number should be less than one if explicit scheme is used. (Correct me if i am wrong).
I see from icoFoam or turbFoam or oodles that the discretization schemes of temporal and convective and viscous terms are implicit, but pressure terms are explicit. But in userguide, Co<1 is demanded for reason of "accuracy" and "stability". So, my questions are: 1. do I still need to think for courant no. since many terms are discretized implicitly? 2. I want to be clear, whether my result is "correct" once my courant number was larger than one during calculation? What I believe is the word "correct" is more important than "accuracy" and "stability". 3. What's the relationship between "stable" and "correct"? I mean what if my courant no. is, say 2 or 3, of which it is said to be unstable, can i believe my result to be correct? Must I be concerned for stability all the way? Thanks for your patience. And finally, Happy new year to you all. (I 'm from China) Daniel
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
courant no | Cfdworker | Phoenics | 5 | October 13, 2006 08:29 |
courant no. | Cfdworker | Siemens | 5 | February 12, 2006 01:04 |
Courant Number | Ramana | CFX | 4 | December 30, 2005 01:51 |
Courant number 999.999 | PetrK | CFX | 3 | December 15, 2005 11:07 |
tutotial and userguide of fluent 6.2.16 | masood yooceframandi | FLUENT | 0 | September 11, 2005 11:51 |
