January 22, 2008, 07:46 |
Dear OpenFOAMers !
I have to
Paul Mauk
Rep Power: 17 |
Dear OpenFOAMers !
I have to solve following 3D case: An oil-separator (cylindric) with an inlet and an outlet. In the middle of the cylinder, orthogonal to inlet and outlet, is a wall with three holes. The case is steady-state end incompessible. I've imported the mesh using fluent3DToFoam. After setting of boundaries and fields I've tried to solve the case, but after 5th step I've got this error message: ... DILUPBiCG: Solving for Uz, Initial residual = 0.763052, Final residual = 0.0167024, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.999999, Final residual = 0.00708348, No Iterations 6 time step continuity errors : sum local = 4.39313e+18, global = 1.0218e+09, cumulative = 1.03986e+09 DILUPBiCG: Solving for epsilon, Initial residual = 0.301803, Final residual = 0.0169611, No Iterations 1 bounding epsilon, min: -4.798e+38 max: 9.64908e+39 average: 2.0208e+35 DILUPBiCG: Solving for k, Initial residual = 0.999984, Final residual = 0.0765404, No Iterations 1 bounding k, min: -8.59358e+23 max: 1.8615e+36 average: 6.48023e+30 ExecutionTime = 391.6 s ClockTime = 400 s Time = 6 DILUPBiCG: Solving for Ux, Initial residual = 0.00270419, Final residual = 7.71289e-05, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.000217164, Final residual = 6.79371e-06, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.0647357, Final residual = 0.0015476, No Iterations 1 #0 Foam::error::printStack(Foam:stream&) in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0x110420] #3 Foam::DICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::DICPreconditioner::DICPreconditioner(Foam::l duMatrix::solver const&, Foam::Istream&) in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::lduMatrix::preconditioner::addsymMatrixConst ructorToTable<foam::dicprecond itioner>::New(Foam::lduMatrix::solver const&, Foam::Istream&) in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #6 Foam::lduMatrix::preconditioner::New(Foam::lduMatr ix::solver const&, Foam::Istream&) in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #7 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #8 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so" #9 main in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam " #10 __libc_start_main in "/lib/libc.so.6" #11 Foam::regIOobject::readIfModified() in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam " what's wrong? |
SimpleFoam Error with librdmacm amp libibverbs | dnomdec | OpenFOAM Running, Solving & CFD | 1 | May 21, 2010 08:02 |
SimpleFoam error | sven82 | OpenFOAM Running, Solving & CFD | 0 | October 16, 2008 04:13 |
Error running simpleFoam in parallel | skabilan | OpenFOAM Running, Solving & CFD | 2 | August 29, 2008 09:42 |
SIMPLEFOAM ERROR ON A RAE2822 | dinonettis | OpenFOAM Running, Solving & CFD | 0 | April 28, 2008 09:50 |
SimpleFoam error message | braennstroem | OpenFOAM Running, Solving & CFD | 1 | October 15, 2007 12:33 |
