SonicTurbFoam crashes when turbulence is added
Old   January 21, 2008, 07:49
Default Hi all, I've been doing com
Denis Semyonov
gastovski is on a distinguished road
I've been doing computations of a transonic flow around an airfoil with high Re, so I've been using sonicTurbFoam solver for this case. Everything went well while I was using laminar turbulence model or no turbulence at all, but when I've added kEpsilon turbulence solver start to crash after the very first timestep iteration (or even in the very beginig in case of kOmegaSST model).
For the inlet BC I use fixed velocity value (M_infinity = 0.8 - 0.9), fixed small k and epsilon. For the outlet BC I've tried both fixed velocity outlet and zero gradient.
Could anybody help me to find out, where is the possible error?
Error messages for the k-epsilon case look like:
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package hThermo<puremixture<consttransport<speciethermo<hc onstthermo<perfectgas>>>>>
Reading field U
Creating turbulence model
Selecting turbulence model kEpsilon
Creating field DpDt
Starting time loop
Time = 1e-07
Courant Number mean: 0.000261797 max: 0.115901
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
GAMG: Solving for Ux, Initial residual = 0.998782, Final residual = 0.000437629, No Iterations 1000
GAMG: Solving for Uy, Initial residual = 1, Final residual = 4.432e-09, No Iterations 2
GAMG: Solving for h, Initial residual = 0.538489, Final residual = 0.0813286, No Iterations 1000
GAMG: Solving for p, Initial residual = 1, Final residual = 1.39313e-08, No Iterations 1000
GAMG: Solving for p, Initial residual = 3.71938e-08, Final residual = 1.68472e-12, No Iterations 1
GAMG: Solving for p, Initial residual = 1.19098e-10, Final residual = 1.19098e-10, No Iterations 0
time step continuity errors : sum local = 8.7637e-10, global = 8.82502e-12, cumulative = 8.82502e-12
GAMG: Solving for p, Initial residual = 6.59328e-07, Final residual = 3.56788e-11, No Iterations 1
GAMG: Solving for p, Initial residual = 1.27284e-09, Final residual = 1.27284e-09, No Iterations 0
time step continuity errors : sum local = 9.11386e-09, global = -1.70428e-10, cumulative = -1.61603e-10
#0 Foam::error::printStack(Foam:stream&) in "/wrk/semyonov/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/wrk/semyonov/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/tls/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/wrk/semyonov/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<foam::fvpatchfield,>(Foam::GeometricF ield<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&) in "/wrk/semyonov/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libcompressibleTurbul enceModels.so"
#5 Foam::tmp<foam::geometricfield<double,> > Foam::operator/<foam::fvpatchfield,>(Foam::tmp<foam::geometricfie ld<double,> > const&, Foam::GeometricField<double,> const&) in "/wrk/semyonov/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libcompressibleTurbul enceModels.so"
#6 Foam::compressible::turbulenceModels::kEpsilon::co rrect() in "/wrk/semyonov/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libcompressibleTurbul enceModels.so"
#7 main in "/wrk/semyonov/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/sonicTur bFoam"
#8 __libc_start_main in "/lib64/tls/libc.so.6"
#9 __gxx_personality_v0 in "/wrk/semyonov/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/sonicTur bFoam"
Floating exception
195.862u 6.226s 3:42.68 90.7% 0+0k 0+0io 2515pf+0w
gastovski is offline   Reply With Quote
Possible sonicTurbFoam bug guusama OpenFOAM Bugs 1 December 17, 2007 12:58
SonicTurbFoam Kaushik Balakrishnan (Balakrishnan) OpenFOAM Running, Solving & CFD 5 May 28, 2007 10:20
added mass Kuba Broniszewski FLUENT 2 February 23, 2007 09:39
SonicTurbFoam anja OpenFOAM Pre-Processing 1 May 22, 2006 06:50
Effect of added CPU ? steve podleski Main CFD Forum 8 August 10, 1999 20:26
