Questions to Dynamic Mesh solver and diffusivity
Like Tree1Likes
  • 1 Post By lr103476
Old   January 10, 2008, 05:16
Default Hi OF-Folks, working on a s
Florian Krause
florian_krause is on a distinguished road
Hi OF-Folks,
working on a simulation of a sinking (rigid) particle in a water cylinder with a modified icoDyMFoam(OF-1.4.1) I run in trouble with the mesh quality.
I tried several diffusivity algorithms:
directional: bad results after a relative short time
quadratic: good results for mesh quality, even if the particle goes through half of the cylinder
exponential: bad and confusing mesh moving after a short time
It was more or less trial and error because I dont really know what the different diffusivity algorithms do and stand for. And I dont know what the values after the keyword stand for, like:
exponential 2000
Does anyone know and has experience with the different diffusivity options and the influence of the values???Is there a documentation of this?
For solvers I use:
dynamicFvMesh dynamicMotionSolverFvMesh
motionSolverLibs libfvMotionSolvers.so
solver velocityComponentLaplacian
I know from several "moving mesh" threads from the forum that there exits other solvers in OF, but does anyone know in which case it is better to use which solver?
I know, alot of question to a often discussed topic. But I really appreciate any help and hints!
Thanks & Kindest Regards,
Flo
florian_krause is offline   Reply With Quote
Old   January 10, 2008, 16:02
Default Hi Florian, Generally quad
Frank Bos
lr103476 is on a distinguished road
Hi Florian,
Generally quadratic inverseDistance diffusivity gives pretty good (if not the best) results for plunging bodies. For that kind of simulations I use the fvMotionSolver, velocityLaplacian. When you are encountering large rotations, the laplacian is not the right equation to use, a good alternative would be the displacementSBRStress motion solver. For really large rotation, subsets of meshes or user defined diffusivity could provide solutions......This is what I am dealing with now :-S
The following paper describes some theory about the laplacian motion solver:
http://powerlab.fsb.hr/ped/kturbo/Op...Manuscript.pdf
Regards, Frank
aow likes this.
Frank Bos
lr103476 is offline   Reply With Quote
Old   January 10, 2008, 16:15
Default How large is you body translat
Frank Bos
How large is you body translation / rotation ???
Frank
Frank Bos
Old   January 10, 2008, 16:41
Default Hi Frank, by now I have no
Florian Krause
Hi Frank,
by now I have no (or very less) rotation of my particle, but I think large deformation.
The paper from Jasak and Tukovic is definitly what I was searching for - its a good discription of the background of the solver and the diffusivity terms
I will send you a two pictures - one of the deformed mesh and one of the undeformed mesh - to your eMail adress ok?!
Regards,
Florian
Old   January 10, 2008, 17:11
Default ok.. I try to post them here
Florian Krause
I use quadratic diffusivity in this case, and at this time I only have some nonorthogonal faces
Regards,
Florian
Old   January 10, 2008, 17:52
Default In fact the screeshot of the d
Florian Krause
In fact the screeshot of the deformed mesh is not really representative and only gives an idea of the mesh deformation... My 3D Mesh only consists of hexa cells, but making a cut in paraView the visualization of the cut cells is very strange - something like R-Trias...
But this is another, not soo important issue ;)
Regards,
Florian
Old   January 11, 2008, 03:04
Default If the sphere is moving down a
Frank Bos
If the sphere is moving down all the way, you really need some cell layering.
Visualization of moving 3D meshes is really a pain, I use ensight to visualize complete cells instead of a cutting plane.....
Frank
Frank Bos
Old   January 11, 2008, 04:33
Default Frank, I agree with you reg
Florian Krause
Frank,
I agree with you regarding the use of additional/removal layer because my cell layers faces are parallel.
But what happens when I have a unstructured Tet mesh? The structued Hex Mesh was only possible because I have only one sphere and buliding the more or less good hex mesh around the cylinder was not the easiest thing.
For the add/rem cell layer I think I need something like:
dynamicFvMeshLibs ("libtopoChangerFvMesh.so");
dynamicFvMesh topoChangerFvMesh;
solver velocityLaplacian ;
How can I define the max and min layer thickness in the dynamicMeshDict?
Regards,
Florian
Old   January 11, 2008, 04:44
Default I haven't use cell layering be
Frank Bos
I haven't use cell layering before, so I don't know ....Try to look inside the code to find out how you define the dictionary....it's quit easy.
Frank
Frank Bos
Old   January 11, 2008, 04:54
Default I found a topo Change movingCo
Florian Krause
I found a topo Change movingCone example from the OF 1.4.1 dev source, I will check on it what is necassary for add/rem cell layers
Regards,
Florian
Old   January 11, 2008, 06:10
Default Florian, for the sphere are yo
  #11
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Florian, for the sphere are you also solving for the conservation of angular momentum?
msrinath80 is offline   Reply With Quote
Old   January 11, 2008, 20:35
Default Hi pUI, when I simulate the
  #12
Florian Krause
Hi pUI,
when I simulate the sinking process, I start with a (0 0 0) velcoity vector for the sphere. For the next iteration I calculate the new velocity for n+1 iteration with the resulting gravity force, the pressure/viscous force and the velocity from iteration n.
Further, I calculate the moments on the sphere BUT I dont use the results for the moments to update the the velocity and dont take into account the possible influence of the moments on the rotation of the sphere.
So, I dont think that I solve the conservation of angular momentum, but its a good hint for the future... ;)
Is this what you mean?
Regards,
Florian
Old   January 11, 2008, 21:33
Default yup, thanks
  #13
yup, thanks
Turbulent compressible solver rhoTurbFoam with dynamic moving mesh eno OpenFOAM Running, Solving & CFD 4 December 12, 2011 03:38
value for dynamic diffusivity soup CFX 0 December 29, 2008 14:14
Bug in turbulent dynamic Mesh Solver thomas OpenFOAM Running, Solving & CFD 0 October 29, 2008 03:48
Problems using dynamic mesh and 6dof solver Brett FLUENT 0 March 3, 2006 17:45
coupled solver and dynamic mesh steph FLUENT 0 June 11, 2004 08:28
