InterFoam MULES solver
Like Tree3Likes
  • 3 Post By santiagomarquezd
Old   December 4, 2007, 11:40
Default Dear OpenFOAM uses and Develop
jaswi is on a distinguished road
Dear OpenFOAM uses and Developers
I request the forum users to shed some light on the details of how MULES works. Please share the information if anybody is aware of it.
I looked into the code and this is what it contains:
1) overloaded function templates for
--> explicitSolve - bounds can be supplied as the function argument;
--> explicitSolve01 - for a scalar bounded between 0 and 1;
--> implicitSolve01 - for a scalar bounded between 0 and 1;
and a function template for
--> limiter
InterFoam uses the MULES solver to solve for the volScalarField gamma and calls
MULES::explicitSolve01(gamma, phi, phiGamma).
This eventually calls the function template
template<class>
void Foam::MULES::explicitSolve
volScalarField& psi,
const surfaceScalarField& phi,
surfaceScalarField& phiPsi,
const SpType& Sp,
const SuType& Su,
const scalar psiMax,
const scalar psiMin
with Sp = zero
Su = zero
psiMax = 1.0
psiMin = 0.0
Could anybody please comment what does template arguments: class SpType, class SuType stand for?
Thanks in advance
Jaswinder
jaswi is offline   Reply With Quote
Old   November 13, 2012, 04:36
joris.hey is on a distinguished road
I think they are representing eventual source terms in the advection equation. There is even this possibility :
void Foam::MULES::explicitSolve  (      const RhoType& rho,      volScalarField& psi,      const surfaceScalarField& phi,     surfaceScalarField& phiPsi,      const SpType& Sp,      const SuType& Su,     const scalar psiMax,      const scalar psiMin  )
with field rho.
How can I call this special MULES function (I need to provide both source terms and rho) ?
I do :
MULES::explicitSolve (oneField (), alpha1 , phi , phiAlpha , volScalarField ("Sp",fvc::div(voidfraction*U)),zeroField (), 1, 0);
But it doesn't compile... What's wrong ?
Cheers,
J
joris.hey is offline   Reply With Quote
Old   November 13, 2012, 05:45
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
Did you look at interPhaseChangeFoam?
See: http://foam.sourceforge.net/docs/cpp/a02688_source.html
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   November 13, 2012, 06:49
yeah, I got it. it was because I should have written geometricOnesField() in place of OneField().
Thanks !
Old   November 21, 2012, 08:56
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi Jaswinder, how you doing? MULES is an Flux Corrected Transport explicit solver for hyperbolic equations. Its implementation mostly follow the ideas of Zalesak limiter but the \lambda's are calculated iteratively. I'm going to give some details in my thesis soon but that's the basic idea.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   November 17, 2020, 02:30
Smile InterFoam learning material/sources
Rohit
Rohitsingh is on a distinguished road
Send a message via Skype™ to Rohitsingh
Hey Jaswi,
I am new entry in this OpenFOAM interFoam solver learners list. Can you share some notes and ideas with me regarding VOF treatment, flow through porous media and other programming aspects in OpenFOAM.
my email id is : singhrohitace4@gmail.com
Rohitsingh is offline   Reply With Quote
Old   June 21, 2022, 08:46
jitendra
j.patel is on a distinguished road
Hi Jaswinder,
I have just started learning the interFoam Solver in OpenFoam V9. I would be very grateful if you could send me some notes. my email id is;
jitendra.patel5789@gmail.com
Thank you in advance
Regards,
Jitendra
j.patel is offline   Reply With Quote
About interFoam solver zou_mo OpenFOAM Running, Solving & CFD 129 December 2, 2019 05:39
Wmake problem interFoam solver feijooos OpenFOAM Running, Solving & CFD 4 December 8, 2008 11:01
DICPCG solver in interFoam m9819348 OpenFOAM Running, Solving & CFD 1 September 20, 2007 13:10
About interfoam solver qiu OpenFOAM Running, Solving & CFD 0 May 6, 2007 22:48
Need documentation for interFOAM solver mer OpenFOAM Running, Solving & CFD 5 May 31, 2006 12:22
