Buoancy
Old   May 26, 2008, 10:53
Default Hi, I am currently developi
Flavio Galeazzo
flavio_galeazzo is on a distinguished road
I am currently developing a solver for incompressible (but with variable density), multicomponent, steady state flow based on simpleFoam. It solves a equation for the concentration, which is used to calculate the density of the mixture. I want now to add the effects of buoyancy, due to density gradients created by the mixture, and I found two ways of doing it:
1. Modifying the pressure equation, as in buoyantSimpleFoam;
2. Adding the "weight" rho*g in the equation of velocity, as in reactingFoam.
With the first approach I don't get convergence. With the second one it converges, but to a wrong solution.
My questions are: What is the difference between these two approaches? There is one that is more suitable to my problem?
flavio_galeazzo is offline   Reply With Quote
Old   May 27, 2008, 03:58
Default Hi, buoyantSimpleFoam is ba
sradl's Avatar
Stefan Radl
sradl is on a distinguished road
buoyantSimpleFoam is based on a compressible fluid solver. Hence, you have to be very careful when using this as you might get problems with stability due to the additional equation for the density!
What I can suggest is to throw away the equation for the density and compute it locally from temperature (and your mixture fraction). Then couple this with a standard incompressible solver and underrelax the density calculation - you should have no problems with convergence.
Second, your wrong result described under 2. maybe due to the fact that the boussinesq approximation you are using does not hold (
http://en.wikipedia.org/wiki/Boussin...%28buoyancy%29
, i.e., you temperature differences are too big.
cheers
Stefan
sradl is offline   Reply With Quote
Old   May 27, 2008, 04:41
Default Thanks for the reply, Stefan!
Flavio Galeazzo
You are right, my maximum density difference is about 7:1, what is too large for the Boussinesq approximation.
I will follow your advice and use the approach from buoyantSimpleFoam. I will post my impressions here, as soon as get good results with it.
Flavio
Old   May 19, 2010, 17:41
Alan Russell
AlanR is on a distinguished road
You could also look at buoyantBoussinesqSimpleFoam, which is an incompressible solver.
Alan
AlanR is offline   Reply With Quote
