Incompatible fields for operation
Old   August 31, 2005, 06:18
Default Hi everybody, I am trying t
Thomas Jung
tehache is on a distinguished road
Hi everybody,
I am trying to solve solidification/melting problems, smearing out release of latent heat over a temperature intervall around melting point, i.e. would like to solve this:
d/dt(rho*cp*T+l*g(T)) -laplacian(DT,T) = 0
Forgetting for the moment cp, rho,l (latent heat),
I created a volScalarField g_T (dimensionSet(0,0,0,1,0,0,0), and assign values (0 below melting point, then a transition, 1 above).
The field T has the same dimension.
Simple-hearted as I am, then tried to do this:
solve
fvm::ddt(T) +fvm::ddt(g_T) - fvm::laplacian(DT, T)
compiles, but then
--> FOAM FATAL ERROR : incompatible fields
for operation [T] + [g_T]
Thank you very much for any hint ...
tehache is offline   Reply With Quote
Old   August 31, 2005, 07:55
Default I think this is because you ar
diablo80@web.de
sampaio is on a distinguished road
I think this is because you are trying to solve for two different variables at the same equation (same matrix).
If you want the term on g(T) implicit, I think you should decompose ddt(g(T)) into something like ddt(g) * ddt(T) using chain rule. If you cannot calculate ddt(g) analitically (gl in chain rule) pehaps you can use something like:
fvc::ddt(g_T)/fvc::ddt(T) * fvm::ddt(T)
\___________________/ \_______/
||||||||||| gl explicit ||||||||||||||||| implicit
You will need some correction tought if fvc::ddt(T) gets close to zero...
(I never tried something like this, better listen to what more experienced people has to say about it... )
sampaio is offline   Reply With Quote
Old   August 31, 2005, 08:17
Default thanks a lot...works with chai
Thomas Jung
thanks a lot...works with chain rule.
In fact somehow trivial, but when you are new to this its sometimes confusing
Old   November 27, 2007, 12:07
Default Hello,all, I am trying to s
Quinn Tian
qtian is on a distinguished road
Hello,all,
I am trying to study anisotropic eddy viscosity effect to my simulation. I created an anisotropic viscosity ternsor "nuEffAn" in the turbulenceModel.H file and also modified the momentum equation in kOmegaSST.C as following.
tmp<fvvectormatrix> kOmegaSST::divR(volVectorField& U) const
return
- fvm::laplacian(nuEffAn(), U)
- fvc::div(nuEffAn()&dev(fvc::grad(U)().T()))+(2.0/3.0)*fvc::grad(k_)
//- Return the effective anisotropic viscosity ternsor
virtual tmp<voltensorfield> nuEffAn() const
tensor T1(1,1,1,1,1,1,1,1,1);
tensor T2(0.6,1,1,1,1,0.6,1,0.6,1);
return tmp<voltensorfield>
new volTensorField("nuEffAn", nut()*T2 + nu()*T1)
After compiled the turbulence model, while I start my simulation, I got following error message:
--> FOAM FATAL ERROR : incompatible fields for operation
[U] + [region0]#0 Foam::error::printStack(Foam:stream&)
#1 Foam::error::abort()
#2 void Foam::checkMethod<foam::vector<double> >(Foam::fvMatrix<foam::vector<double> > const&, Foam::fvMatrix<foam::vector<double> > const&, char const*)
#3 Foam::tmp<foam::fvmatrix<foam::vector<double> > > Foam::operator+<foam::vector<double> >(Foam::tmp<foam::fvmatrix<foam::vector<double> > > const&, Foam::tmp<foam::fvmatrix<foam::vector<double> > > const&)
#4 main
#5 __libc_start_main
#6 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i386/elf/start.S:122
From function checkMethod(const fvMatrix<type>&, const fvMatrix<type>&)
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.4/src/finiteVolume/lnInclude/fvMatrix.C at line 1005.
Can anybody tell me what I did wrong? Thanks.
qtian is offline   Reply With Quote
Old   April 7, 2010, 06:48
mediode
mediode is on a distinguished road
@tehache
could you please be more specific on the chain rule applied. I have some doubt that ddt(g)*ddt(T) is correct, I think it should be ddT(g)*ddt(T) instead. Something like ddT is not implemented in OF, or?
Please corect me if I'm wrong.
Cheers
m*
mediode is offline   Reply With Quote
Old   January 30, 2018, 15:32
Zhi Cheng is on a distinguished road
Have you solved this problem? Thanks!
I will be greatly appreciated if you replied me.
Originally Posted by qtian View Post
Hello,all,
return
[U] + [region0]#0 Foam::error:rintStack(Foam:stream&)
#3 Foam::tmp<foam::fvmatrix<foam::vector<double> > > Foam:perator+<foam::vector<double> >(Foam::tmp<foam::fvmatrix<foam::vector<double> > > const&, Foam::tmp<foam::fvmatrix<foam::vector<double> > > const&)
#4 main
Zhi Cheng is offline   Reply With Quote
Incompatible fields for operation divphi Ub vvqf OpenFOAM Running, Solving & CFD 4 April 4, 2018 03:28
incompatible fields for operationproblem in simpleFoam kbr OpenFOAM Running, Solving & CFD 3 March 10, 2009 10:25
Incompatible fields for operation su_junwei OpenFOAM Pre-Processing 1 October 15, 2008 08:34
TurbFoam simpleFoam incompatible fields for operation braennstroem OpenFOAM Running, Solving & CFD 0 June 19, 2008 10:43
The incompatible of UDF Summer FLUENT 3 April 23, 2007 04:11
