Why my code is ok with single processor but doesnbt work in openmpi |
November 23, 2007, 13:44 |
I need compute wallshe
xiuying
Rep Power: 17 |
I need compute wallshearstress and wrote a code as followings. when I use single processor, it worked well. But if I use openmpi and multiprocessor, it couldn't work and there was not wallshearstress data written. Could you inform me how to deal with the problem? Thanks. volSymmTensorField R(turbulence->R()); volVectorField wallShearStress ( IOobject ( "wallShearStress", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedVector("wallShearStress", R.dimensions(), vector::zero) ); //label patchA = mesh.boundaryMesh().findPatchID("lowerWall"); //patchID=0; // Info<< "End2\n" << endl; forAll(wallShearStress.boundaryField(), patchi) { wallShearStress.boundaryField()[3] = ( -mesh.Sf().boundaryField()[3] /mesh.magSf().boundaryField()[3] ) & R.boundaryField()[3]; } if(runTime.outputTime()) { wallShearStress.write(); } kang |
Cases with small length scale work fine on a single processor but fail in parallel | adona058 | OpenFOAM Bugs | 5 | April 17, 2009 04:41 |
Why the noslip doesnbt work | corenc | OpenFOAM Running, Solving & CFD | 9 | August 26, 2008 07:26 |
Max mesh size on single processor? | JP | CFX | 2 | November 4, 2007 17:02 |
Install doesnbt work | hplum | OpenFOAM Bugs | 7 | August 14, 2007 04:45 |
Why doesnbt the macro forall work for the volVectorField variable | siwen | OpenFOAM Running, Solving & CFD | 2 | February 24, 2006 15:27 |
