Convection discretization schemes for LES
Like Tree17Likes
Old   November 19, 2007, 17:00
Default Dear Forum, just as an obse
  #21
Alessandro Spadoni
gtg627e is on a distinguished road
Dear Forum,
just as an observation that I forgot to attach to the previous message, Uz velocity is indeed symmetric about the x-y plane. This gives me confidence that cyclic boundary conditions are being enforced correctly.
Thank you again,
Alessandro
gtg627e is offline   Reply With Quote
Old   November 19, 2007, 18:04
Default Sorry, I meant to say: "Uz
  #22
Alessandro Spadoni
"Uz velocity is indeed cyclic about the x-y plane"
Alessandro
Old   July 11, 2012, 03:18
Ehsan
ehsan is on a distinguished road
Hello
Could I kindly ask you whether applying "LES Model: laminar" in Les Property folder will create implicit LES in OPENFOAM? If no, how we should apply implicit LES in OPENFOAM?
Thanks in advance
ehsan is offline   Reply With Quote
Old   April 6, 2015, 09:04
Andy_bm is on a distinguished road
Originally Posted by eugene View Post
2. Initial conditions: k should have a small positive value (1e-10)
Can you explain why initial conditions for k should have small value? And how to calculate initial conditions for k?
Andy_bm is offline   Reply With Quote
Old   April 9, 2015, 11:27
Eric Robertson
msuaeronautics is on a distinguished road
K should always tend to zero at the wall, as it represents your modeled portion of turbulence kinetic energy. In the case of LES, K is the (modeled) turbulence energy of the subgrid scales. Since velocity -> 0 as we get down to the wall, so should the energy.
msuaeronautics is offline   Reply With Quote
Old   April 9, 2015, 13:38
Thanks,
What about nusgs near wall? Maybe there is a ratio between nusgs and nu? In oneeqeddy nusgs = c*delta*sqrt(k). If k -> 0, delta -> 0 as y+ ~ 1 => nusgs -> 0.But nusgs may varried depending on k and y+.And I don't understand what value of nusgs should be near wall.
Old   April 9, 2015, 14:09
Eric Robertson
Thanks,
nuSgs -> 0
is the correct BC for the wall (if, for nothing else, the equation you wrote there) and really is the only reasonable one.
How nuSgs varies as we start to move away from the wall (as y+ increases) depends on your method. You could either be using a wall function for nuSgs or you could have a sufficiently fine grid (suspect this would be the case for most people using LES) to properly represent it.
Please let me know if I'm not being clear.
Old   April 9, 2015, 15:19
Now I have BC on wall for nusgs - zeroGradient, so I must set fixedValue = 0 if y+ ~ 1?
Sorry,I don't understand initial condition for k on WALL must be near 0 or initial condition on INLET must ~ 0?
Old   April 9, 2015, 15:34
Eric Robertson
No need to apologize.
Yes, for nuSgs and y+ ~1, you may use nuSgs_WALL ~ 0.
Your condition for K_WALL should also be near 0.
I am assuming you are using 1-equation eddy. The condition for inlet can be K_INLET ~ 1e-5 or 1e-6. In other words, some small value but not zero. It really depends on your case. The only time I've used 1-equation eddy I used that condition and got good results.
Old   April 9, 2015, 15:58
Thanks for your answers!
My case is flow past cylinder.I have mesh with y+ 0.1-1. And I have following problem if I use k_inlet~0.96 (1.5(UI)^2) -> Cd ~0.8. if k_inlet~0.01-0.0001 -> Cd~0.3 but in experiment Cd~0.55+-.
Old   April 9, 2015, 16:01
Eric Robertson
How are you calculating Cd? Are you using an ensemble average of a list of outputs?
Old   April 9, 2015, 16:23
I use libforces.lib and then plot result in labplot.For k~0.96 pulsation of coeffs occur near 0.8, for small k near 0.3.End time is sufficiently large.
Old   April 9, 2015, 16:34
Eric Robertson
That makes sense.
I have done study on sphere using DDES. I take the time average of the flow and compute the drag from the sum of pressure and viscous forces acting on the body from the mean solution. Maybe you could try that also for comparison. Drag gets a little tricky when using libforces, especially for an unsteady simulation.
Old   April 11, 2015, 00:12
And what scheme for grad and div(phi,U) did you use?
Old   April 11, 2015, 21:07
Eric Robertson
Based on my studies, limitedLinear works pretty well for DES. Avoid the upwind/2nd order upwind schemes like the plague. I use a k value of 0.1-0.3 based on trial and error using a simple case; i.e.
Gauss limitedLinear 0.3;
Old   May 18, 2015, 11:53
What about internalField for k? Did you set this = k_inlet value or 0?
Old   May 18, 2015, 11:55
Eric Robertson
I usually set this equal to k_inlet.
Old   November 28, 2015, 13:41
openfoammaofnepo is on a distinguished road
Dear Eugene,
Thank you for this suggestions. Do you know any papers or threads in which the LES results from linear and this filteredLinear2V for convection scheme are compared or validated? In the latter, we have two parameters that can be adjusted: "filteredLinear2V 0.2 0". If the first one (0.2 here) is small, this scheme seems equilevant to the linear. The comments from the source file are:
   // Scaling corefficient for the gradient ratio,
        // 0 = linear
        // 1 = fully limited
For the second parameter, in the source files, we have the following comments:
   // Maximum allowed overshoot/undershoot relative to the difference
        // across the face.
        // On input:
        //     0 = no overshoot/undershoot
        //     1 = overshoot/undershoot equal to the difference across the face
        // Note: After input 1 is added to l_
I am not sure I completely understand this usage of the second parameter. Could you please give an example? Thanks.
The link for the source file is here:
https://github.com/OpenFOAM/OpenFOAM-2.1.x/blob/master/src/finiteVolume/interpolation/surfaceInterpolation/limitedSchemes/filteredLinear2/filteredLinear2V.H
Thanks.
openfoammaofnepo is offline   Reply With Quote
Old   July 31, 2017, 14:30
Timofey Mukha
tiam is on a distinguished road
Originally Posted by openfoammaofnepo View Post
Dear Eugene,
        // 0 = linear
        // across the face.
        // On input:
Thanks.
This is an old thread but I would like to revive it. I assume much more people have done LES on OF by now. Any developments on convective schemes? As for filteredLinear, we have 5 to choose from (including the V variants) and also a bunch of parameters. Any guidelines/suggestions?
tiam is offline   Reply With Quote
AMG parallelisation and convection schemes christian OpenFOAM Running, Solving & CFD 3 December 17, 2007 08:21
Discretization scheme for Convection Terms Mohammad Kazemi CFX 16 December 7, 2004 22:38
Convection Term Discretization Maciej Matyka Main CFD Forum 3 October 7, 2004 04:32
discretization schemes alice FLUENT 1 July 28, 2004 15:58
differencing schemes for 3-D Convection-diffusion problems Nuray Kayakol Main CFD Forum 20 September 16, 1999 04:16
