Channel flow with twoPhaseEulerFoam
Old   September 27, 2007, 09:05
Default Hi everybody. I'm trying to s
joao carneiro
joao is on a distinguished road
Hi everybody.
I'm trying to solve a simple case to test the twoPhaseEulerFoam solver. The problem is that of the demixing of bubbles flowing through a channel dispersed in water. But I have some problem. After a couple of time steps, reversed flow occurs at the outlet boundary. I assume there is some problem with the BC. Is there anybody who had a similar problem? I set the boundary condition as follows:
Ua
boundaryField
inlet
type fixedValue;
value nonuniform List<vector>
18
(0 0 0)
(0.0319305 0 0)
(0.0635875 0 0)
(0.0943479 0 0)
(0.123419 0 0)
(0.1498 0 0)
(0.172243 0 0)
(0.189193 0 0)
(0.19873 0 0)
(0.19873 0 0)
(0.189193 0 0)
(0.172243 0 0)
(0.1498 0 0)
(0.123419 0 0)
(0.0943479 0 0)
(0.0635875 0 0)
(0.0319305 0 0)
(7.21645e-17 0 0)
outlet
type zeroGradient;
lowerWall
type slip;
upperwall
type slip;
defaultFaces
type empty;
Ub
boundaryField
inlet
type fixedValue;
18
(0 0 0)
(0.0319305 0 0)
(0.0635875 0 0)
(0.0943479 0 0)
(0.123419 0 0)
(0.1498 0 0)
(0.172243 0 0)
(0.189193 0 0)
(0.19873 0 0)
(0.19873 0 0)
(0.189193 0 0)
(0.172243 0 0)
(0.1498 0 0)
(0.123419 0 0)
(0.0943479 0 0)
(0.0635875 0 0)
(0.0319305 0 0)
(7.21645e-17 0 0)
outlet
type zeroGradient;
lowerWall
type fixedValue;
value uniform (0 0 0);
upperwall
type fixedValue;
defaultFaces
type empty;
alpha
boundaryField
inlet
type fixedValue;
value uniform 0.0257;
outlet
type zeroGradient;
lowerWall
type zeroGradient;
upperwall
type zeroGradient;
defaultFaces
type empty;
I also tried to change the BC to "calculated" but
unfortunately with no success. I get the following message:
--> FOAM FATAL IO ERROR : keyword value is undefined in dictionary "/nfs/home/lee/OpenFOAM/lee-1.4.1/run/tutorials/twoPhaseEulerFoam/channelFlow_in ternal/0/alpha::outlet"
file: /nfs/home/lee/OpenFOAM/lee-1.4.1/run/tutorials/twoPhaseEulerFoam/channelFlow_int ernal/0/alpha::outlet from line 42 to line 42.
From function dictionary::lookupEntry(const word& keyword) const
in file db/dictionary/dictionary.C at line 146.
FOAM exiting
Thanks for any hint.
Joao.
joao is offline   Reply With Quote
Channel flow DNS alberto OpenFOAM Running, Solving & CFD 20 February 17, 2016 17:26
Channel flow DNS Abhinav Main CFD Forum 1 April 11, 2013 06:37
maintain a constant flow rate in channel flow ? Lewis Main CFD Forum 2 September 28, 2010 11:35
LES channel flow Hadi FLUENT 0 September 20, 2007 05:15
BC for 2d channel flow khan Main CFD Forum 1 January 31, 2007 23:26
