September 4, 2007, 06:04 |
Hi all
I read the "Two fundam
morteza
Rep Power: 17 |
Hi all
I read the "Two fundamental questions about icoFoam while updating the velocities and pressure" in discussion group and know that OpenFOAM solves pressure(p) not pressure correction(p'). But i want to add an additional term to pressure correction equation. Should i implement this equation or it is available now? For example there is a pressure correction equation in the attached pdf file(eqn. 2). \attach Thanks in advance |
September 4, 2007, 06:07 |
Hi all
morteza
Rep Power: 17 |
Hi all
I read the "Two fundamental questions about icoFoam while updating the velocities and pressure" in discussion group and know that OpenFOAM solves pressure(p) not pressure correction(p'). But i want to add an additional term to pressure correction equation. Should i implement this equation or it is available now? For example there is a pressure correction equation in the attached pdf file(eqn. 2). Thanks in advance |
September 4, 2007, 06:16 |
Hi all
morteza
Rep Power: 17 |
Hi all
I read the "Two fundamental questions about icoFoam while updating the velocities and pressure" in discussion group and know that OpenFOAM solves pressure(p) not pressure correction(p'). But i want to add an additional term to pressure correction equation. Should i implement this equation or it is available now? Sorry, file is too big to attach. I choose a pressure correction equation from "L. Mangani" article about OpenFoam and it is as follows: Thanks in advance |
Nature of Pressure Correction Equation | Abhijit Tilak | Main CFD Forum | 10 | April 10, 2016 17:03 |
BCs for Pressure Correction Equation (SIMPLE) | Bharath Somayaji | Main CFD Forum | 1 | March 1, 2006 06:12 |
Preconditioning for Pressure Correction Equation | cfd101 | Main CFD Forum | 1 | February 23, 2006 14:34 |
reg pressure-correction equation | saritha | Main CFD Forum | 0 | January 29, 2004 20:45 |
B.C. for pressure-correction equation | Jeff Kang | Main CFD Forum | 1 | October 22, 2003 09:16 |
