How can we use the point patch fields given in OpenFOAM141srcfvMotionSolverpointPatchFieldsderive d
Old   August 17, 2007, 14:19
Default Hi community.. Can some bod
jaswi is on a distinguished road
Hi community..
Can some body please explain how one can use the point patch fields given in :
/home/singh/OpenFOAM/OpenFOAM-1.4.1/src/fvMotionSolver/pointPatchFields/derived
There are following options available:
--> angularOscillatingDisplacement
--> angularOscillatingVelocity
--> oscillatingDisplacement
--> oscillatingVelocity
As far as my understanding goes they have to do something with the meshMotion :-).
The next doubt i have is this:
the velocityLaplacian solver requires pointMotionU and cellMotionU. can one use the above pointFields to specify the pointMotionU and cellMotionU like this:
FoamFile
version 2.0;
format ascii;
root "interFoam";
case "meshMotion";
instance "0";
local "";
class volVectorField;
object cellMotionU;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
cube
type oscillatingDisplacement;
amplitude (0.5 0 0);
omega 0.25;
value uniform (0 0 0);
FoamFile
version 2.0;
format ascii;
root "interFoam";
case "meshMotion";
instance "0";
local "";
class pointVectorField;
object pointMotionU;
boundaryField
cube
omega 0.25;
If this is completely wrong then please advice how one could specify the pointMotionU and cellMotionU ,
which is required to use the velocityLaplacian solver
Thanks alot
Jaswinder
jaswi is offline   Reply With Quote
HELP NEEDED HOW TO MAP VALUES FROM PATCH OF ONE MESH TO PATCH OF ANOTHER MESH mkraposhin OpenFOAM Running, Solving & CFD 3 September 4, 2011 09:42
[OpenFOAM] Average fields jml ParaView 4 December 15, 2008 11:55
Point coordinates via orinial point address after decomposing diana OpenFOAM Running, Solving & CFD 0 August 6, 2008 10:27
Array of fields r2d2 OpenFOAM Running, Solving & CFD 11 January 30, 2008 12:40
Boundary patch fields ariorus OpenFOAM Post-Processing 8 July 7, 2006 19:02
