Two instances of lamd
Old   August 10, 2007, 14:58
Default Is it possible to have two ins
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Is it possible to have two instances of lamd on one 4 CPU machine (for instance). Then one could run two 2-CPU jobs independent of each other.
msrinath80 is offline   Reply With Quote
Old   August 10, 2007, 15:12
Default Got it. Using varying values o
Got it. Using varying values of the environment variable LAM_MPI_SESSION_SUFFIX before running lamboot.
Old   August 10, 2007, 15:37
Default Hey Srinath, Quick question
Philippose Rajan
philippose will become famous soon enough
Hey Srinath,
Quick question... what happens if you have a 4 CPU machine, and you run lamboot once...
And then, run "mpirun -np 2 ......." two times? Wont the Linux kernel automatically assign two processors for one "mpirun", and the other two for the second "mpirun" ??
I very often run one parallel run (with two processors...using one "mpirun -np 2 ...."), and one normal run on a Quad Core.
I have found that leaving one processor in a Quad Core free actually speeds things up, compared to a parallel run which uses all 4 processing cores....would you able to confirm that for me ?
Have a nice evening!
Philippose
philippose is offline   Reply With Quote
Old   August 10, 2007, 16:36
Default Quick question... what happens
Frankly, I don't know! I think it depends on how many nodes you specified in the machines file you supplied to lamboot.
With regards to the quad-core, my analysis can be found here[1].
Hope that helps!
[1] http://www.cfd-online.com/OpenFOAM_D...tml?1181823034
Old   August 10, 2007, 17:05
Default Hmmmm..... When you use "mpiru
Philippose Rajan
Hmmmm..... When you use "mpirun -np <n>", you dont need to specify the number of nodes for the lamboot command....
I usually use a file called "machines", in which I put in the IP of the machine I use... example:
127.0.0.1
Thats it... and then... "lamboot -v machines"
Specification of the number of nodes is done in the "mpirun -np <n>" command.
Anyway... shall try this out on Monday... no access to the Quad core over the weekend.
Have a nice weekend!
Philippose
Old   August 10, 2007, 17:10
Default I'm pretty sure of one thing t
I'm pretty sure of one thing though. One instance of the LAM daemon (lamd) cannot support two separate MPI instances. Otherwise I wonder why would they provide for a LAM_MPI_SESSION_SUFFIX variable?
Anyways, I eagerly look forward to your quad-core results.
