Convergence troubles
Old   July 18, 2007, 04:23
Default Hi everybody ! Yesterday, I s
Guillaume Lodier
guimch is on a distinguished road
Hi everybody !
Yesterday, I started a new thread about the same subject but I'm afraid I wasn't clear enough. So let me remind you what is going wrong.
I have to compare results given by Fluent and OpenFoam in an industrial test case. I used fluentMeshtoFoam to use the same mesh as fluent to make my comparison possible.checkMesh told me that at this point everything is ok. I am using the simpleFoam solver since my flow is incompressible, steady state and turbulent. My inlet is a non-uniform velocity field (a swirl whose max velocity amounts to 12 m/s). Using paraView, I could check that my swirl is well modeled. When I turn the option "turbulence" off, Foam start the calculation without any trouble. But when "turbulence" is on, I get the following error message :
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model CrossPowerLaw
Selecting turbulence model kEpsilon
Starting time loop
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.0291, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0176, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0124, No Iterations 1
AMG: Solving for p, Initial residual = 1, Final residual = 1, No Iterations 0
time step continuity errors : sum local = 1.59e+06, global = 1.59e+06, cumulative = 1.59e+06
#0 Foam::error::printStack(Foam:stream&)
#1 Foam::sigFpe::sigFpeHandler(int)
#2 Uninterpreted: [0x2ee420]
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&)
#4 void Foam::divide<foam::fvpatchfield,>(Foam::GeometricF ield<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&)
#5 Foam::tmp<foam::geometricfield<double,> > Foam::operator/<foam::fvpatchfield,>(Foam::tmp<foam::geometricfie ld<double,> > const&, Foam::GeometricField<double,> const&)
#6 Foam::turbulenceModels::kEpsilon::correct()
#7 main
#8 __libc_start_main
#9 __gxx_personality_v0 at ../sysdeps/i386/elf/start.S:122
Floating exception
It seems to be a convergence trouble... So,
I had a look on advices given in the Message Board about the same kind of problem, I change some parameters as shown on message but Foam keep on telling me the same message.
I hope that someone could help me because I haven't got idea anymore.
Thanks you !
Guillaume
guimch is offline   Reply With Quote
Old   July 25, 2007, 13:19
Default See the answer in the other th
Assistant Moderator
Bernhard Gschaider
See the answer in the other thread (k or epsilon==0)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
UDF troubles Rachel FLUENT 1 June 29, 2008 23:02
Convergence troubles with 3D heat exchanger simula Balcazar - Capetillo FLUENT 2 June 13, 2008 01:22
AMG troubles - help? Stephanie Siemens 1 September 22, 2007 14:03
3d VOF troubles... Mac FLUENT 0 March 12, 2007 08:41
some troubles with "USER_GET_GVAR" Ardisia CFX 3 February 13, 2007 23:21
