How to change a term of an equation
Old   July 4, 2007, 08:46
Default Hi I would like to change t
dimitri bonnet
dimi is on a distinguished road
Hi
I would like to change the laplacian term in the momentum predictor in sonicFoam.C to get something like :
div( 2*mu (0.5(grad(U)+t.grad(U)) - 1/3*div(U) I) )
Do I have to keep the form of the left-hand side operators : operator(xxx, U) ? like div(phi,U) or can I do something like :
fvc::div(2.0*mu*(symm(fvc::grad(U))-1.0/3.0*fvc::div(U)*I)) ?
When I do that way, I can compile but I can't execute, I obtain this error :
Caught FoamXIOError exception in FoamXCaseServer::main(int argc, char **argv) :
FoamXIOError "Non-optional dictionary entry 'div(2.0*mu*(symm(fvc::grad(U))-1.0/3.0*fvc::div(U)*I))' not found in dictionary\
/home/dbonnet/OpenFOAM/OpenFOAM-1.4/applications/solvers/compressible/nsonicFoam /FoamX/defaults/system/fvSchemes::divSchemes"
File "/home/dbonnet/OpenFOAM/OpenFOAM-1.4/applications/solvers/compressible/nsonicFoa m/FoamX/defaults/system/fvSchemes::divSchemes" starting at line 39 ending at line 44
Thank you
Dimitri
dimi is offline   Reply With Quote
Old   July 4, 2007, 09:08
Default What you're experiencing is a
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
What you're experiencing is a FoamX-error (it can't find the correct discretization scheme for your expression).
At first. If your solver differs from the original solver, call it differently (for instance: dimitrisSonicFoam). It saves you a lot of confusion later.
As soon as you have done that it won't work with FoamX anymore. Two solutions:
1. Write cfg-files to support your solver in FoamX
2. Use the solver from the command-line (without FoamX)
Solution 2 is easier (really!). The solver WILL complain about missing entries on fvSchemes of your case, but these can be easily added by hand.
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   July 4, 2007, 09:26
Default Hi Bernhard and thank you for
dimitri bonnet
Hi Bernhard and thank you for your answer
I had changed the name of the solver "nsonicFoam" instead of "sonicFoam".
I have tried to change the cfg-files, but it doesn't work, I would like to know if it is because of the attributes of the operator which are not the same than operators used for the rest of the programm.
So do you know how to change the the cfg-files to run the case with FoamX ?
Furthermore, when I use the command-line, I get the error :
--> FOAM FATAL IO ERROR : keyword div(2.0*mu*(symm(fvc::grad(U))-1.0/3.0*fvc::div(U)*I)) is undefined in dictionary "/home/dbonnet/OpenFOAM/dbonnet-1.4/run/tutorials/nsonicFoam/testmarche/system/f vSchemes::divSchemes"
Thank you
Dimitri
Old   July 4, 2007, 09:50
Default Hi Dimitri! No. I once fidd
Assistant Moderator
Bernhard Gschaider
Hi Dimitri!
No. I once fiddled around with these cfg-files and decided not to do it again if it can be avoided (which doesn't mean that the concept is bad, it's just that I don't use FoamX and it's therefor not worth the effort for me)
Your error: I predicted that in the previous posting. Edit the fvSchemes-file to have an entry in the divSchemes-subdictionary. The format is quite easy to understand (but it is also documented in Chapter 4 of the User Guide)
Bernhard
Old   July 4, 2007, 10:32
Default <> should be something like li
Assistant Moderator
Bernhard Gschaider
<> should be something like linear/upwind. <> is just a placeholder (for FoamX I think). There is a whole section in chapter 4 dedicated to the discussion of what is valid for fvSchemes (an absolute must-read if you're working outside of FoamX)
Old   July 4, 2007, 10:43
Default Ok thank you I will work again
dimitri bonnet
Ok thank you I will work again on that.
RANS equation - don't understand a term Micael Boulet FLUENT 3 July 31, 2008 18:32
How to add a source term in u or v equation? luckyluke Phoenics 3 December 13, 2004 02:52
Add source term in species equation zhou1 FLUENT 1 October 21, 2003 06:28
UDF sourse term for VOF equation ROOZBEH FLUENT 5 April 22, 2003 06:56
buoyant term in vorticity equation junomian Main CFD Forum 1 September 17, 2002 05:28
