July 3, 2007, 16:52 |
I am trying to writ
Doug Hunsaker
I am trying to write my own turbulence model and am currently studying the kEpsilon model in OF 1.4 linked with simpleFoam. In the simpleFoam.C source file, it says: phi = fvc::interpolate(U) & mesh.Sf(); I'm not exactly sure what's happening here. My best guess is that it's interpolating the vector U from the cell centers to the cell faces and storing it as the transport property phi. (What exactly is the "& mesh.Sf()?) In the kEpsilon.C source file, the dissipation equation is solved using phi_ as the item of transport. The divergence of phi_ is calculated as part of that equation. However, I thought you could only calculate the divergence of a vector. Is phi_ somehow a vector now instead of a scalar? If so, how was it set? I'm assuming that the phi defined in simpleFoam.C is the same as the phi_ in kEpsilon.C. Since velocity is the item of transport, could the phi_ in the turbulence model be replaced by U_? This would be a true vector. Thanks for your help. Doug |
July 3, 2007, 19:50 |
Hi Doug,
As I understand it
Shaun Cooper
Hi Doug,
As I understand it fvc::interpolate(U) & mesh.Sf() is, as you say, the interpolation of the velocity from the cell centre to the cell face, the '&' is the dot product symbol, see programmer's guide, and meshSf() is the face area magnitudes. So this is saying, interpolate the velocity field and take the dot product with the face area vector. Not too sure about the rest, Hope this helps, Shaun |
July 4, 2007, 04:28 |
@"However, I thought you could
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
@"However, I thought you could only calculate the divergence of a vector. Is phi_ somehow a vector now instead of a scalar?": According to Gauss's theorem (http://en.wikipedia.org/wiki/Divergence_theorem) the divergence in a volume can be calculated by summing the flux on the surfaces. phi is just that (the flux on the surface). So I guess (havn't looked at the code for that) div(phi) does just that: sum up the phis on the surface and pretend it's div(U)
November 10, 2009, 04:33 |
#4 | |
isabel
However, phi is a "surfaceScalarField" (not a vector). What div(phi) is? And why you can compute a divergence of an scalar? By definition, divergence is applied to a vector, for a scalar it would be a gradient. |
July 4, 2007, 10:20 |
Hi Bernhard,
If you think (
Hoang-Lam
Hi Bernhard,
If you think (as Shaun) that div(phi) is something like div(U), do you think that I have well implemented: nu*laplacian(U)=grad(div(U))/epsi (I obtained this expression by considering: div(U)=epsi*p, where epsi is very small (epsi [0 -2 1 0 0 0 0] 1e-6)) and nu*Laplacian(U)=grad(p) by writting in Foam: tmp<fvvectormatrix> UEqn(laplacian(nu,U)); solve(UEqn()==fvc::grad(fvc::div(phi)/epsi)); ? Lam |
which turbulence model to use??? | Ravikanth | CFX | 1 | April 3, 2008 18:03 |
Turbulence Model | GG | Siemens | 3 | March 3, 2008 19:06 |
changing model constants in k-e turbulence model | Sunil | CFX | 3 | October 3, 2006 12:12 |
Best Turbulence Model | manish | FLUENT | 1 | March 10, 2005 18:15 |
HELP! TURBULENCE k-e OR k-omega TURBULENCE MODEL? | Mirek Kabacinski | FLUENT | 5 | August 24, 2003 22:31 |
