SonicTurbFoam
Old   February 2, 2005, 10:56
Default I am using the SonicTurbForm
Kaushik Balakrishnan (Balakrishnan)
I am using the SonicTurbForm solver. Under 'thermophysicalProperties' there is a field titled 'thermoType'. I tried all the options available from the drop down menu, but all of them give me an error. Could you please tell me which option I need to choose and how (if its not from the drop down menu).
Thanks
Old   February 3, 2005, 08:41
Default Let me show you how it's done:
Hrvoje Jasak (Hjasak)
thermoType is defined in constant/thermophysicalProperties.
The option in the tutorial is (screwed up newsgroup software, please try it out)
"hThermo>>>>"
As with all other run-time selection scheme, if you want to know what all the options are, try putting garbage in and the code will tell you. For example, if I set:
thermoType banana;
The (relevant part) of the output says:
--> FOAM FATAL ERROR : Unknown basicThermo type banana
Valid basicThermo types are :
2
"hThermo>>>>"
"hThermo>>>>"
If I were you, I'd give up on the pre-processor as soon as I could.
Enjoy,
Hrv
Old   February 3, 2005, 09:28
Default The thermo package needed for
Henry Weller (Henry)
The thermo package needed for sonicTurbFoam and the other sonic solvers can be found in the tutorials for those codes. Th package you need to specify is
<BLOCKQUOTE>hThermo<pureMixture<constTransport<spe cieThermo<hConstThermo<perfectGas>>>>></BLOCKQUOTE>
which as you say isn't on the list in the FoamX configuration files but I have added for the next release but if you need it now simply add it to the list in the file
$FOAMX_SYSTEM_CONFIG/dictionaries/thermophysicalProperties/thermoType.cfg
It is unfortunate that the FoamX files are not completely up-to-date but we no longer have anyone maintaining them due to lack of funds so we encourage everyong who finds problems with them to report the errors preferably with fixes.
Old   February 3, 2005, 10:13
Default Incidentally, there is some in
Admin (Admin)
Incidentally, there is some information about the thermo stuff in:
http://www.openfoam.org/doc/userse33.html
Old   August 2, 2006, 09:09
Default A slight correction....the inf
David P. Schmidt
schmidt_d is on a distinguished road
A slight correction....the information about the thermo stuff is actually at:
http://www.opencfd.co.uk/openfoam/doc/userse32.html
schmidt_d is offline   Reply With Quote
Old   May 28, 2007, 10:20
Default Hej, I am running the "buo
mss
Hej,
I am running the "buoyantFoam" case and I have a several questions concerning it:
1. Can someone give me a hint where OpenFoam is cheking the mixture name in the code?
2. Could someone clearify to me what mathematical model (system of equations) exactly OpenFOAM is solving in "buoyantFoam" case?
Thank you for help in advance,
Rita
Possible sonicTurbFoam bug guusama OpenFOAM Bugs 1 December 17, 2007 12:58
Looking for description of sonicTurbFoam tangd OpenFOAM 0 June 13, 2006 01:20
Problems with sonicTurbFoam tangd OpenFOAM Running, Solving & CFD 0 May 29, 2006 09:07
SonicTurbFoam anja OpenFOAM Pre-Processing 1 May 22, 2006 06:50
SonicTurbFoam initialisation anger OpenFOAM Running, Solving & CFD 3 April 6, 2006 09:35
