Hydrostatic head
Old   March 5, 2007, 09:11
Default I am about to simulate the "hi
Holger Putz
holger is on a distinguished road
I am about to simulate the "hidrostatic head" of a simple column (cylinder full of water).
the remaining equation to solve is actually dp/dz=rho*g (1)
So, I added the gravity to the momentum equation and set u-vectors equal to zero. No inlet to the cylinder and no outlet. Just water. And I want to calculate the pressure difference between the top and the bottom of the cylinder.
however the result is not matching the equation
p(top)-p(bottom)=rho*g*h (2)
and I dont have an explanation for that.
Henry netioned in the board that the pressure p in simpleFoam is rho/p. If I take the equation into account, the calculated result is not matching eq.(2) anyway.
Unfortunately, I dont know how to handle that situation in OpenFoam. What BC do I need for this job?
Any help you can give would be very much appreciated.
Regards,
Holger
holger is offline   Reply With Quote
Old   March 6, 2007, 16:20
Default Hello Holger, I am also hav
Shaun Cooper
coops is on a distinguished road
Hello Holger,
I am also having problems with hydrostatic equilibrium. I would also like to know if someone has a solution for this problem.
Shaun
coops is offline   Reply With Quote
hydrostatic pressure Amanda FLUENT 6 April 20, 2016 11:00
Hydrostatic pressure(rho*g*h) Pranesh FloEFD, FloWorks & FloTHERM 3 October 17, 2008 06:18
hydrostatic pressure attax CFX 0 September 8, 2005 09:27
hydrostatic pressure multiphase FLUENT 0 May 18, 2003 15:16
Hydrostatic Pressure Rhydar CFX 3 March 6, 2002 09:54
