FOAM FATAL ERROR Maximum number of iterations exceeded
Like Tree17Likes
Old   January 28, 2016, 03:05
Baris (Heewa)
shipman is on a distinguished road
Hi Francis,
Thank you for your advice. It also lets me solve my problem.
BR.
shipman is offline   Reply With Quote
Old   February 26, 2016, 11:37
S Atkinson
satkinson is on a distinguished road
I am using a Cht K epsion model using Openfoam and I keep getting this error.
I have tried changing the maxiter to 10000 and still get the problem too. Did anyone get to the bottom of this? I completely remade my mesh and still get this same error although I have a few overly skewed faces (64 failed skewness faces) and 900 faces failing nonOrthag check, however due to the geometry even if I used SHM these errors would still occur.
I tried Francis's method and this has't solved it.
I have noticed a sharp (impossible) rise in density in certain regions of the fluid, this was so sharp that it shouted alarm. However I am unfamiliar with this type of modelling so thought I would ask for some advice.
I previously attended the Advanced Openfoam training course and have emailed the guy who ran it (as has my work mate) regarding problems which he encouraged. Unfortunately he does not respond to emails, which has left me a bit discouraged.
Cheers
satkinson is offline   Reply With Quote
Old   June 28, 2016, 06:27
Moritz
Momo1805 is on a distinguished road
Hey everyone,
I recently ran into the same issue using the sprayFoam solver with version OF2.4 and an implemented ignition. The error especially ocurrs when I ignite more than one cell and I think it must be due to the Newton solver used to calculate the temperature. Eventually it ocurrs with only one ingiting cell as well though. Has anyone solved this issue so far?
@sahul could you provide the implented brent solver?
Thanks in advance
Moritz
Momo1805 is offline   Reply With Quote
Old   July 5, 2016, 10:34
S Atkinson
Hi Moritz,
Have you had any luck on this one?
I have noticed that my temperatures are diverging too for no reason. I riginally solved the issue by switching to the plane wall 2d solver, however I have got the error again now.
Old   July 5, 2016, 15:53
Default Maximum number of iterations exceeded
  #25
Henry
hbrist7 is on a distinguished road
I've been having a lot of trouble tracing the source of this error. I know it happens in the thermoI.H file, but I can't trace what is calling that, or figure out any reason why this is happening. I've had no luck trying to fix this on my own for a while now.
The case i am running is a simple wedge (meshed with snappy hex mesh) inside a blockmesh region using rhoCentral foam.
any help would be really appreciated
this is the error log file
|  \\    /   O peration     | Version:  3.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 3.0.1-119cac7e8750
Exec   : rhoCentralFoam -parallel
Date   : Jul 01 2016
Time   : 12:54:38
Host   : "cfd01"
PID    : 30359
Case   : /----/wedge15maxIterError
nProcs : 36
Slaves :
35
"cfd01.30360"
"cfd01.30361"
"cfd01.30362"
"cfd01.30363"
"cfd01.30364"
"cfd01.30365"
"cfd01.30366"
"cfd01.30367"
"cfd01.30368"
"cfd01.30369"
"cfd01.30370"
"cfd02.26571"
"cfd02.26572"
"cfd02.26573"
"cfd02.26574"
"cfd02.26575"
"cfd02.26576"
"cfd02.26577"
"cfd02.26578"
"cfd02.26579"
"cfd02.26580"
"cfd02.26581"
"cfd02.26582"
"cfd03.29133"
"cfd03.29134"
"cfd03.29135"
"cfd03.29136"
"cfd03.29137"
"cfd03.29138"
"cfd03.29139"
"cfd03.29140"
"cfd03.29141"
"cfd03.29142"
"cfd03.29143"
"cfd03.29144"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
Reading field U
Creating turbulence model
Selecting turbulence model type laminar
fluxScheme: Kurganov
Starting time loop
Mean and max Courant Numbers = 0.00521015 0.119072
deltaT = 2.4e-06
Time = 2.4e-06
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for Ux, Initial residual = 0.999285, Final residual = 0.00389594, No Iterations 5
smoothSolver:  Solving for Uy, Initial residual = 0.999999, Final residual = 8.69665e-17, No Iterations 5
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 8.81879e-17, No Iterations 5
diagonal:  Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for e, Initial residual = 1.46977e-11, Final residual = 1.46977e-11, No Iterations 0
ExecutionTime = 0.68 s  ClockTime = 1 s
Mean and max Courant Numbers = 0.00625242 0.142579
deltaT = 2.88e-06
Time = 5.28e-06
smoothSolver:  Solving for Ux, Initial residual = 6.23273e-10, Final residual = 6.23273e-10, No Iterations 0
smoothSolver:  Solving for Uy, Initial residual = 1.24042e-05, Final residual = 6.5351e-18, No Iterations 5
smoothSolver:  Solving for Uz, Initial residual = 0.00028774, Final residual = 4.85118e-17, No Iterations 5
smoothSolver:  Solving for e, Initial residual = 5.7298e-12, Final residual = 5.7298e-12, No Iterations 0
[0] [1]
[1]
[1] --> FOAM FATAL ERROR:
[1] Maximum number of iterations exceeded
[1]
[1]     From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar)const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>]
[1]     in file /home/openfoam/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66.
[1]
FOAM parallel run aborting
[1]
[2]
[2]
[2] --> FOAM FATAL ERROR: [3]
[3]
[3] --> FOAM FATAL ERROR:
[3] Maximum number of iterations exceeded
[3]
[3]     From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar)const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>]
[3]     in file /home/openfoam/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66[7]
[7]
[7] --> FOAM FATAL ERROR:
[7] Maximum number of iterations exceeded
[7]
for reference, my P/T/U files are here:
p:
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 18822.7;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 18822.7;
    outlet
        type            zeroGradient;
    airplane
	type		zeroGradient;
    bottom
        type            zeroGradient;
    top
        type            zeroGradient;
    symmetry
	type		symmetryPlane;
    left
	type 		zeroGradient;
    defaultFaces
        type            zeroGradient;
T:
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 216.65;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 216.65;
    outlet
        type            zeroGradient;
    airplane
	type		zeroGradient;
    bottom
        type            zeroGradient;
    top
        type            zeroGradient;
    left
	type		zeroGradient;
    symmetry
	type		symmetryPlane;
    defaultFaces
        type            zeroGradient;
U:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (400 0 0); //(246.933 0 0);
boundaryField
    inlet
        type		fixedValue;
        value           uniform (400 0 0); //(246.933 0 0);
    outlet
        type            zeroGradient;
    airplane
	type		slip;
    bottom
        type            zeroGradient;
    top
        type            zeroGradient;
    left
	type		zeroGradient;
    symmetry
	type		symmetryPlane;
    defaultFaces
        type            zeroGradient;
hbrist7 is offline   Reply With Quote
Old   July 5, 2016, 23:06
Baris (Heewa)
Hi Henry,
Most probably your T value is going to negative or extremely high. To see in into T.Eqn file add Info << T.min() << " " << T.min() <<endl;
then you can understand reason.
hope it helps you.
Baris
Old   July 6, 2016, 15:54
Henry
It looks like that was the problem, but I'm lost as to how to go about solving it. What can I do to prevent T from going out of control like that?
Old   July 13, 2016, 15:52
Moritz
Hey together,
could anyone please explain me how I can compile the thermo files if I want for example some output debugging in the thermoI.H file??? I somehow don't understand where these files are included in any Make/files...
Any help would be sincerely appreciated
Thanks and cheers
moritz
Old   July 13, 2016, 16:50
Henry
go to the directory that includes the thermoI.H file, and once you edit whatever debugging code you want into that file, type "wclean" and then "wcompile", which should recompile all the files in that directory for you
Old   July 14, 2016, 04:26
Moritz
Hi henry,
I didnt want to do it as root but I guess it is easier. But still it's not giving me the info in my logfile I acutally wrote in the code. Why?
template<class Thermo, template<class> class Type>
inline Foam::scalar Foam::species::thermo<Thermo, Type>::T
    scalar f,
    scalar p,
    scalar T0,
    scalar (thermo<Thermo, Type>::*F)(const scalar, const scalar) const,
    scalar (thermo<Thermo, Type>::*dFdT)(const scalar, const scalar)
        const,
    scalar (thermo<Thermo, Type>::*limit)(const scalar) const
) const
    scalar Test = T0;
    scalar Tnew = T0;
    scalar Ttol = T0*tol_;
    int    iter = 0;
    Info<< "Test = " << Test << endl;
    Info<< "   f = " << f << endl;
    do
        Test = Tnew;
        Tnew =
            (this->*limit)
            (Test - ((this->*F)(p, Test) - f)/(this->*dFdT)(p, Test));
            scalar Thilf = mag(Tnew - Test);
            Info<< "DeltaT = " << Thilf << endl;
        if (iter++ > maxIter_)
            FatalErrorIn
                "thermo<Thermo, Type>::T(scalar f, scalar T0, "
                "scalar (thermo<Thermo, Type>::*F)"
                "(const scalar) const, "
                "scalar (thermo<Thermo, Type>::*dFdT)"
                "scalar (thermo<Thermo, Type>::*limit)"
                "(const scalar) const"
                ") const"
            )   << "Maximum number of iterations exceeded"
                << abort(FatalError);
    } while (mag(Tnew - Test) > Ttol);
    return Tnew;
Old   July 14, 2016, 05:10
Moritz
Ok, sorry for the stupid question. You have to compile the whole thermophysical folder if anyone faces the same problem at some point.
Thanks anyway guys!
Old   July 21, 2016, 17:44
Default chtMultiRegionSimpleFoam - Solution suggestion
  #32
Peter Hess
peterhess is on a distinguished road
Hello Everybody,
Increasing the Mesh quality by increasing the number of cells solved my divergence problem and no error massage appeared anymore.
- My mesh is created by blockMesh
- chtMultiRegionSimpleFoam has been used as a test
- I left the maximum iterations by 100 (did not followed the suggestion above)
- in my test I gave: runTimeModifiable false
I hope it can helps
Regards
Peter
peterhess is offline   Reply With Quote
Old   July 25, 2016, 09:33
Moritz
Dear foamer,
I solved the problem. In my case, the error occurred because of different values for T_common in the therm.dat file. Make sure that all reactants involved in the chemical reactions have the same value for T_common. But I think in the current version this bug is already fixed.
Cheers
zhangyan likes this.
Old   September 6, 2016, 05:02
Talking
  #34
Junqian CAI
acaist is on a distinguished road
Originally Posted by Momo1805 View Post
Dear foamer,
Cheers
Your suggestion is valuable and useful. By unify all T_common in chemistry, I solve the problem that the temperature show non-convergence in version 3.0 with reduced chemistry. And I found another post talking about this, which might be helpful to understand the cause.http://www.cfd-online.com/Forums/ope...ombustion.html
acaist is offline   Reply With Quote
Old   October 12, 2016, 09:12
Default Resolved
  #35
Vijaya Kumar. G
VIJAYA KUMAR is on a distinguished road
1) Reduce delta T to a order 10000 times lower than the current value.
2) Set Max Courant Number to 1
3) Set ´adjustTimeStep´ to yes
try running the solver again, if it crashes yet again, reduce the delta T even lower then try running again.
This worked for me.
The problem was with higher courant number and that leading to a diverged solution.
VIJAYA KUMAR is offline   Reply With Quote
Old   March 29, 2017, 07:19
Hrushikesh Khadamkar
Hrushi is on a distinguished road
Originally Posted by srahul View Post
Hi Michu,
You can find the the script in here
OpenFOAM-2.2.0/src/thermophysicalModels/specie/thermo/thermo/thermoI.H
In this file Newton solver (Line no. 41 - 88) is utilised to calculate the T. I implemented brent solver and now that problem is solved.
Dear Rahul,
We are also struggling with this issue of temperature update using N-R method. Can you share your brent method code implemented in thermoI.H file? We also feel that by using Brent method, this problem can be solved.
Hrushilesh
Hrushi is offline   Reply With Quote
Old   March 31, 2017, 17:42
Andrea Matiz C
andreamc is on a distinguished road
hi
Did you find a solution to your problem? I'm having the same problem with the compressible solver rhoSimpleFoam.
Thanks in advance!
andreamc is offline   Reply With Quote
Old   April 3, 2017, 14:47
Andrea Matiz C
Hi
I'm having the same ṕroblem you mentioned. Did you manage to solve it? what did you do?
Thanks in advance
Andrea
Old   April 5, 2017, 09:53
amin jalalian
amin_jalalian is on a distinguished road
Hi Michu,
In this file Newton solver (Line no. 41 - 88) is utilized to calculate the T. I implemented brent solver and now that problem is solved.
Hi srahul
I have some questions, How can make the thermoI.H file?
Can you send brent solver text in openFoam?
thanks
amin_jalalian is offline   Reply With Quote
Old   May 15, 2017, 05:45
Default My mistake was...
  #40
Peter Hess
Hello Everybody!
chtMultiRegionSimpleFoam has been used here!
I faced the problem also like many of you.
I tried almost everything has been written here without a success...
I increased the number of cells to a very high number (1 000 000) cells for 100 x 100 x 100 mm region(s).
That worked, but the results where very strange.
And I found the mistake I made!
I made the folowing:
- 3D Design FreeCAD then export as stl
- Used blockMesh to make my initial mesh
- In openFoam using snappyMesh to build my final mesh
The dimensions in my stl file were in mm. That means FreeCAD exports the 100...
snappyMesh read this 100 as 100 m instead of the 100 mm exported
My blockMesh mesh is also too big made (factor 1000)...
Reducing the dimensions in factor 1000 bei:
convertToMeters 0.001 in blockMeshDict
AND
in my exported stl file (FreeCAD)
Solved my problem!
Check up the dimensions (in your blockMeshDict as example) is my suggestion here.
Regards
Peter
maximum number of iterations solomon FLUENT 7 April 25, 2024 02:27
Maximum number of iterations exceeded liugx212 OpenFOAM Running, Solving & CFD 3 August 28, 2013 08:09
FOAM FATAL IO ERROR msrinath80 OpenFOAM Running, Solving & CFD 4 July 30, 2008 10:06
Internal Error: Number of tree levels exceeded ahlo CFX 0 March 4, 2008 13:45
FOAM FATAL ERROR derath OpenFOAM Pre-Processing 1 June 10, 2006 14:20
