Carrays
Old   January 16, 2007, 19:03
Default Hi For some reason my code
shuo
Hi
For some reason my code keeps giving me a segmentation fault when there are too many arrays(70*70) calculations? Is it to do with memory?
SHuo
Old   January 17, 2007, 06:15
Default you can check the used memory
Markus Hartinger
hartinger is on a distinguished road
you can check the used memory with the command 'top', but my guess is, that you access your array out of its bounds
hartinger is offline   Reply With Quote
Old   January 22, 2007, 05:54
Default "flow_field(){variable = 0;}"
Mattijs Janssens
"flow_field(){variable[VertG][HoriG] = 0;}" will index outside 'variable'.
Use e.g. valgrind to pick up these errors.
Carrays shuo OpenFOAM Running, Solving & CFD 0 January 16, 2007 19:09
