How to use icoDyMFOAM
Old   August 11, 2006, 15:17
Default I have spent quite a while loo
Bryan Godbolt
soup is on a distinguished road
I have spent quite a while looking at openFoam's different solvers and I think icoDyMFOAM will do what I want. However I can't find anything on how to use it.
I hope i'm just missing something but is there someone who could tell me where to look for documentation on icoDyMFOAM. I would also like to know more about dynamicMeshDict. Where can I find out what options are available and what the options do?
Any help is greatly appreciated.
soup is offline   Reply With Quote
Old   August 14, 2006, 10:29
Default Could someone even point me in
Bryan Godbolt
Could someone even point me in the direction of the source code that reads in dynamicMeshDict? I have been looking at the source for icoDyMFoam and trying to follow all the #includes but I haven't been able to track it down.
Old   August 14, 2006, 10:34
Default Not that it's going to do you
Hrvoje Jasak
Not that it's going to do you any good, but the piece of code you are looking for is:
OpenFOAM-1.3/src/dynamicFvMesh/dynamicFvMesh/newDynamicFvMesh.C, line 39.
It then does run-time selection from available dynamic meshes and the story continues in the selected mesh type.
Enjoy,
Hrv
Hrvoje Jasak
Old   August 14, 2006, 11:53
Default Thank you for your reply. A
Bryan Godbolt
As far as I can tell no documentation exists for icoDyMFoam. Could you please confirm this or do I need to look harder?
You're right that line of code doesn't do me much good. Is there a better way for me to find out how to use dynamicMeshDict to set up a dynamic mesh?
Thanks again
Old   August 15, 2006, 06:51
Default Bryan - unfortunately I don't
irc
Ian Cowan
irc is on a distinguished road
Bryan - unfortunately I don't think there is any real documentation - this takes time to produce, I guess, and everyone's busy. As a fellow initiate to dynamic meshes under OF, I can only suggest that you spend some time reviewing the tutorial cases and trawling through the threads on this message board related to dynamic/moving meshes - you should then begin to put the pieces together. When you have a more specific question on how a certain bit works, then you may get more of a response. Good luck!
irc is offline   Reply With Quote
Old   November 23, 2006, 10:55
Default Hello everybody, I am trying
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hello everybody,
I am trying the icoDyMFoam on a very simple case, a solid cube rotating inside a sphere:
From the first time step I get the following error:
lap08 mjukvara-1.3/run> ~/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPDebug/icoDyMFoam ./ sliding
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.3 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : /lap08/soft/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPDebug/icoDyMF oam ./ sliding
Date : Nov 23 2006
Time : 16:50:24
Host : lap08
PID : 29131
Root : /lap08/soft/OpenFOAM/mjukvara-1.3/run/
Case : sliding
Nprocs : 1
Create time
Create mesh
Selecting dynamicFvMesh mixerFvMesh
void mixerFvMesh::addZonesAndModifiers() : Zones and modifiers already present. Skipping.
Mixer mesh:
origin: (0 0 0)
axis: (0 0 1)
rpm: 10
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Courant Number mean: 0 max: 0
deltaT = 5.99995e-06
Time = 5.99995e-06
ICCG: Solving for pcorr, Initial residual = 1, Final residual = 7.39948e-09, No Iterations 91
ICCG: Solving for pcorr, Initial residual = 0.779809, Final residual = 9.59514e-09, No Iterations 85
time step continuity errors : sum local = 3.36793e-19, global = -1.16263e-34, cumulative = -1.16263e-34
BICCG: Solving for Ux, Initial residual = 1, Final residual = 1.48658e-11, No Iterations 1
BICCG: Solving for Uy, Initial residual = 1, Final residual = 1.55559e-11, No Iterations 1
BICCG: Solving for Uz, Initial residual = 1, Final residual = 1.45563e-11, No Iterations 1
ICCG: Solving for p, Initial residual = 1, Final residual = 9.0969e-07, No Iterations 72
ICCG: Solving for p, Initial residual = 0.565172, Final residual = 7.47717e-07, No Iterations 69
time step continuity errors : sum local = 2.05296e-19, global = 4.27936e-34, cumulative = 3.11673e-34
--> FOAM FATAL ERROR : Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
fixedMassOut: 0.465426 massIn: 0.465426 diff: 3.44336e-12
From function
adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p
in file cfdTools/general/adjustPhi/adjustPhi.C at line 108.
FOAM exiting
How 3.4e-12 can be too large error? Any sugestions on how to proceed further?
Dragos
dmoroian is offline   Reply With Quote
Old   November 23, 2006, 11:21
Default Hi Dragos, I'm also trying
Vincent RIVOLA
vinz is on a distinguished road
Hi Dragos,
I'm also trying to use icoDymFOAM solver at this time.
As far as I know, such errors are occuring because of boundary conditions problems, especialy for the pressure. So check that way, andd try different possibilities.
Hope it was helpful,
Vincent
vinz is offline   Reply With Quote
Old   November 24, 2006, 03:25
Default Hmm, This is strange, because
dmoroian's Avatar
Dragos
Hmm,
This is strange, because I have only wall boundaries. So the only pressure condition I can think of is zeroGradient.
Dragos
Relative Fluxes in icoDyMFoam deepsterblue OpenFOAM Running, Solving & CFD 7 July 20, 2012 02:39
Mesh Problem with icoDyMFoam yuhai OpenFOAM Running, Solving & CFD 5 January 14, 2009 14:57
Problem with icoDyMFoam olivier OpenFOAM Running, Solving & CFD 13 December 19, 2008 09:03
Problem with icoDyMFoam tutorial matlie OpenFOAM Bugs 10 April 26, 2007 04:51
Problem with icoDyMFoam philippose OpenFOAM Running, Solving & CFD 19 March 7, 2007 12:06
