IOobject constructor problem
Old   November 17, 2006, 23:05
Default i wish to calculate the mean f
iyer_arvind
i wish to calculate the mean flow (and many other calculations) from time say 0.1s to 10.0s and write the final output in folder say Avg (at the same level as 0.1,0.2,0.3, ... 10.0) so for the corresponding volScalarField if i write the IOobject in its constructor as
U_bar(IOobject("U_bar","Avg",mesh .... )...)
it doesn't work. I guessed that the second arg indicated the folder which is generally runtime.TimeName(), and replaced it with "Avg"
can you please help?
thanks a lot
Old   November 18, 2006, 23:59
Default is this thing possible? and ho
iyer_arvind
is this thing possible? and how can i make OpenFOAM read a particular file from a particular directory? i would want OpenFOAM to read the files from the Avg Directory, if i can get it written.
Old   November 19, 2006, 03:17
Default regIOobjects can only be read
Hrvoje Jasak
regIOobjects can only be read or written from time directories, system or constant. If you really insist on having them elsewhere, open your own OFstream and put the file wherever you like.
Hrv
Hrvoje Jasak
Old   November 19, 2006, 06:39
Default Thanks, now i can quit tryin
iyer_arvind
Thanks,
now i can quit trying to do it with all combinations possible, and take another route, as suggested.
IOobject r2d2 OpenFOAM Running, Solving & CFD 20 May 5, 2016 08:16
Face Set Constructor for star v4.02 gonnafon Siemens 1 June 6, 2012 09:16
MultiComponentMixture constructor prashant24983 OpenFOAM Running, Solving & CFD 5 February 7, 2011 15:54
A question on IOObject ivan_cozza OpenFOAM 0 September 16, 2008 03:24
