Customized solver to run in parallel
Old   September 9, 2006, 08:26
Default Hi, I have a customized sol
Pei-Ying Hsieh
hsieh is on a distinguished road
I have a customized solver (not a standard OpenFOAM solver). It ran fine in serial. When I ran it in parallel, AMG failed. Changed to ICCG/BICCG, ran with only a warning at each time step. I have not checked whether the results are correct.
When looking at the code, is there a way to tell whether it is "parallel-ready"?
Pei
hsieh is offline   Reply With Quote
Old   September 20, 2006, 12:57
Jojo
jojo is on a distinguished road
I have a customized solver as well. However, I do not manage to run it in parallel while it runs fine in serial.
I get the following message:
It seems that [at least] one of the processes that was started with
mpirun did not invoke MPI_INIT before quitting (it is possible that
more than one process did not invoke MPI_INIT -- mpirun was only
notified of the first one, which was on node n0).
mpirun can *only* be used with MPI programs (i.e., programs that
invoke MPI_INIT and MPI_FINALIZE). You can use the "lamexec" program
to run non-MPI programs over the lambooted nodes.
It seems that wmake compilation of custom solvers has an issue with parallelization (I have seen another post with the same problem).
jojo is offline   Reply With Quote
Old   September 20, 2006, 14:46
Default Hey, I think first you woul
Markus Hartinger
hartinger is on a distinguished road
Hey,
I think first you would need to understand the existing solvers like GaussSeidel. Set up a very simple test case like 10x1x1 cells and a very simple equation and check whether each processor receives what you would expect.
markus
hartinger is offline   Reply With Quote
Old   September 21, 2006, 04:59
Default - make sure your solver uses a
Mattijs Janssens
mattijs is on a distinguished road
- make sure your solver uses argList to extract the command line options
- make sure your solver gets called with a -parallel option
mattijs is offline   Reply With Quote
AMG Solver in parallel fra76 OpenFOAM Running, Solving & CFD 13 February 22, 2007 02:38
Parallel execution of customized solver otsuki OpenFOAM Running, Solving & CFD 2 March 24, 2006 07:47
Parallel solver with 3.2 robbie Siemens 1 August 10, 2004 07:29
3D PARALLEL SOLVER (MPI Lib) Saud Khashan Main CFD Forum 8 July 14, 1999 08:52
