dynamic mesh motion (angularOscillatingDisplacement) in OF1.6 |
May 12, 2010, 11:29 |
Tamás Baksa
Dear Foamers,
I'd like to simulate the flow around an oscillating cross-section. The shape is very simple it is almost like a rectangle. I had to define very fine boundary layer resolution in order to stay below y+<1. The chord length of my shape is 1 [m] and the first cell next to the wall is 0.04e-3 [m]. My constant/dynamicMeshDict looks like: Code:
dynamicFvMesh dynamicMotionSolverFvMesh; solver displacementLaplacian; motionSolverLibs ("libfvMotionSolvers.so"); diffusivity quadratic inverseDistance 1(fixedWalls); // **************************************** // Code:
... boundaryField { [inlet, outlet, frontAndBack description] fixedWalls { type angularOscillatingDisplacement; // angle = angle0_ + amplitude_*sin(omega_*t.value()); axis (0 0 1); // direction origin (0 0 0); angle0 0; amplitude 0.17453; // 10 deg in rad omega 6.2832; // 1Hz * (2pi) value uniform (0 0 0); // ??? } } // ********************************************* // Code:
Mesh non-orthogonality Max: 179.989 average: 7.45988 *Number of severely non-orthogonal faces: 318. ***Number of non-orthogonality errors: 50. ***Error in face pyramids: 204 faces are incorrectly oriented. http://img526.imageshack.us/img526/7...edmesha183.png Do you have any idea how to avoid this? 1) Maybe using different diffusivity fields? According to Jasak and Tukovic paper [1] I should try diffusivity proportional to the distortion energy. But none of the available diffusivity keywords sound like dist. energy in OF1.6: Code:
10 ( uniform quadratic file motionDirectional inverseDistance inversePointDistance inverseFaceDistance directional inverseVolume exponential ) Code:
5 ( dynamicMotionSolverFvMesh // I'm using this one solidBodyMotionFvMesh dynamicRefineFvMesh dynamicInkJetFvMesh staticFvMesh // mesh has no motion ) ps: my time step is sufficiently small, I think: 2e-4 [1] http://powerlab.fsb.hr/ped/kturbo/Op...tionFAMENA.pdf [2] http://www.aero.lr.tudelft.nl/~frank/index.php?id=research/cfd/problems/2D_movingmesh_wing |
May 13, 2010, 10:53 |
Kevin Smith
Rep Power: 17 |
If you can conform your mesh around the body to a circle, you could use GGI to oscillate the body, which would avoid mesh deformation. Take a look at the mixerGGI example and code, it is fairly easy to change the driving function to a cosine signal.
If you don't want to change your mesh or simply cannot conform the mesh surrounding the body to a circle, I would look into the subset motion as Eric mentioned or RBF mesh motion. |
May 13, 2010, 12:22 |
Kevin Smith
Rep Power: 17 |
Ah, you are correct.
dynamic mesh on a hexa grid | Manoj Kumar | FLUENT | 4 | August 8, 2010 08:28 |
Turbulent problems during Dynamic Mesh Motion | arturojortega | FLUENT | 2 | June 2, 2009 10:33 |
Discrete Values for Mesh Motion | UnderwaterAlex | CFX | 2 | February 21, 2008 18:21 |
dynamic mesh on a hexa grid | Manoj Kumar | FLUENT | 0 | August 21, 2007 07:41 |
Dynamic mesh + grid adapt = Crash! (Files included | BillH | FLUENT | 4 | July 24, 2007 15:31 |
