Problem with compressibility rhoSimpleFoam
Old   August 3, 2006, 13:50
Default Hi, I am working on simulat
Greg Zink
gzink is on a distinguished road
I am working on simulating swirling flow through a nozzle. I have been able to run steady-state incompressible flow using simpleFoam, but when I attempt to run the same geometry compressibly using rhoSimpleFoam the pressure goes negative.
I am using:
- Atmosphere BCs at inlet and outlet (totalPressure and pressureInletOutletVelocity)
- Default discretization except div(phi,U) which is limitedLinearV 1.0
- Cyclic boundary conditions
- Relatively low under-relaxation factors (0.2 p, 0.4 U, 0.1 k, eps, h, and rho)
Varying these parameters changes when the pressure goes negative, but it always does at some time or another. The blowup appears in a straight channel portion of the domain where a region of low pressure will move upstream, followed by high pressure, then low, etc. There seems to be no effect on velocity that I can see as a result of these pressure oscillations.
I am just about out of ideas as to what could be causing this. Does anyone know what might be wrong and what I can do to fix it? I'd appreciate any advice you can give.
Thanks.
Greg Z.
gzink is offline   Reply With Quote
RhoSimpleFoam maritozzo OpenFOAM Running, Solving & CFD 1 April 30, 2010 18:18
RhoSimpleFoam problem with patch nishant_hull OpenFOAM Running, Solving & CFD 15 October 30, 2009 12:51
RhoSimpleFoam jphandrigan OpenFOAM Running, Solving & CFD 18 March 29, 2009 11:05
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
RhoSimpleFoam luca OpenFOAM Running, Solving & CFD 0 August 22, 2005 12:26
