July 28, 2006, 08:47 |
Hi All.
I want to run a Tay
Julio Manuel Barros Jr.
Rep Power: 17 |
Hi All.
I want to run a Taylor-Couette flow case with the outer cylinder fixed and a rotating inner cylinder . The mesh is OK, but I'm having trouble to set the B.C. for the rotating cylinder. What B.C and which solver I should use? I know it must be simple to set but I'm a newbie to C++ and OpenFOAM. Thanks, Julio Barros |
results for flow past flat plate normal to flow | lisa | Main CFD Forum | 2 | August 30, 2005 16:36 |
External Flow-compressible flow solver-lift/drag | Tom Brown | Main CFD Forum | 7 | December 29, 2000 13:41 |
