Collection Codes OpenFoam
Old   July 3, 2006, 17:11
Default Hello, I am new to CFD and I
larry
larry is on a distinguished road
I am new to CFD and I am toying around with the tutorial examples provided by OpenFoam.
I am experiencing this problem with engineFoam.
I generate the mesh (mesh-generation ---> blockmesh), then I try visualizing it with parafoam using:
paraFoam /home/lorenzo/OpenFOAM/OpenFOAM-1.3/tutorials/engineFoam kivaTest
but then paraFoam crashes with the output:
--> FOAM FATAL ERROR : Cannot find file "points" in directory "constant/polyMesh"
From function Time::findInstance(const word& dir, const word& name)
in file db/Time/findInstance.C at line 133.
FOAM exiting
Why is "points" not created? I did not have this problem when trying the icoFoam case following the pdf guide. Any suggestions?
Furthermore, is there anything like a collection of OpenFoam codes? For instance, in my case I need to model the flow coming from the mixing of the air out of two pipes (same axis, one injecting air inside the other), but I am finding it hard set it up correctly (starting from the mesh generation)
Many thanks
Lorenzo
larry is offline   Reply With Quote
Collection Efficiency in Fluent? Jason FLUENT 8 May 5, 2015 03:18
Collection of simple functionObjects gschaider OpenFOAM 48 July 31, 2014 10:06
NASA COSMIC COLLECTION D.D Main CFD Forum 1 May 18, 2006 13:20
Collection efficiency Jen FLUENT 0 November 16, 2005 10:16
Data output collection simon Main CFD Forum 0 September 29, 2003 09:03
