Hanging pointer
Old   January 9, 2006, 07:41
Default Hello, I have a problem reco
Fabian Peng Karrholm
fabianpk is on a distinguished road
I have a problem reconstructing parallel cases, and I do not use any cyclic boundaries. I have a wedge mesh, with wall, wedge, symmetryPlane and patch as boundaries. When I try to reconstructPar I get:
Reconstructing volScalarFields
rho
--> FOAM FATAL ERROR : hanging pointer, cannot dereference
From function PtrList::operator[] const
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/PtrListI.H at line 76.
This just turned up one day as I was reconstructing a mesh. I use uncompressed, binary, but I don't think this matters because the error even turns up for the 0 time directory.
/Fabian
fabianpk is offline   Reply With Quote
Old   January 9, 2006, 08:58
Default Wedges and cyclics are quite s
Eugene de Villiers
eugene is on a distinguished road
Wedges and cyclics are quite similar to each other. I imagine the bug fix posted in the bug forum will take care of your problem.
eugene is offline   Reply With Quote
Old   January 10, 2006, 02:01
Default Unfortunately it did not work,
Unfortunately it did not work, the only difference is taht the reference to PtrListI.H refers to the one in my home directory and not the one in /home/dm2/henry
/Fabian
Old   January 10, 2006, 04:24
Default Can you report it as a bug and
Mattijs Janssens
mattijs is on a distinguished road
Can you report it as a bug and add a simple testcase?
mattijs is offline   Reply With Quote
Old   January 10, 2006, 05:38
Default Yes, here's a wedge if I decom
Yes, here's a wedge if I decompose this using decomposePar, and then try to reconstruct it, I get the error. So I don't have to create some new data to do it.
http://www.tfd.chalmers.se/~f98faka/...ngPoint.tar.gz
/Fabian
Old   January 10, 2006, 05:57
Default Reproduced it. You've got a
Hrvoje Jasak
Reproduced it.
You've got a patch called axis with zero faces in it in the original mesh and the code does not handle it. For my taste, you should get rid of the zero-sized patch because you don't need it.
Hrv
#4 0x4053b75c in Foam::error::abort (this=0x40b31720) at error.C:224
#5 0x0806dbfe in Foam::operator<<> (os=@0x8105650, m={fPtr_ = {__pfn = 0x4053b4ca <foam::error::abort()>, __delta = 0}, err_ = @0x40b31720}) at errorManip.H:85
#6 0x08083d32 in Foam::PtrList<foam::fvpatchfield<double> >::operator[] (this=0xbf8dff70, i=5) at PtrListI.H:76
#7 0x0808d631 in GeometricBoundaryField (this=0x9510f64, bmesh=@0xbf8e0a94, field=@0x9510f10, ptfl=@0xbf8dff70) at GeometricBoundaryField.C:200
#8 0x0809ef47 in GeometricField (this=0x9510ed8, io=@0xbf8dfff8, mesh=@0xbf8e01f8, ds=@0x950fc60, iField=@0xbf8dff7c, ptfl=@0xbf8dff70) at GeometricField.C:277
#9 0x0809fbb6 in Foam::geometricFvFieldReconstructor::reconstructFv VolumeField<double> (this=0xbf8e0f14, fieldIoObject=@0x950f648)
at geometricFvFieldReconstructorReconstructFields.C:2 24
#10 0x0809fe6d in Foam::geometricFvFieldReconstructor::reconstructFv VolumeFields<double> (this=0xbf8e0f14, objects=@0xbf8e0ec0)
at geometricFvFieldReconstructorReconstructFields.C:4 64
#11 0x0807936a in main (argc=3, argv=0xbf8e14b4) at reconstructPar.C:241
Hrvoje Jasak
Old   January 10, 2006, 07:10
Default You mean that the axis patch o
You mean that the axis patch of a wedge should not be set and just left empty?
/Fabian
Old   January 10, 2006, 07:32
Default Yes - I've deleted the axis pa
Hrvoje Jasak
Yes - I've deleted the axis patch from the mesh before the decomposition and it works.
Hrv
Hrvoje Jasak
Old   January 28, 2011, 10:29
Sandy Lee
sandy is on a distinguished road
Hi eugune, in my case I use the cyclic boundaries. Now I meet the same problem "... hanging pointer, cannot dereference ...", you think, what should I do? Please help out.
sandy is offline   Reply With Quote
FATAL ERROR hanging pointer cannot dereference tsencic OpenFOAM Running, Solving & CFD 8 January 7, 2021 03:10
Hanging Elements Dipl.-Ing. Jayadi Lukito CFX 0 January 29, 2008 03:18
postprocessing keeps hanging leo FLUENT 1 October 22, 2007 09:16
Accessing a pointer away from current pointer shephali shrimali FLUENT 0 May 10, 2007 07:54
hanging fan Mavinakere. FLUENT 3 August 3, 2003 22:34
