Total pressure boundary condition
Old   December 10, 2005, 12:56
Default Hi everybody!! I have to anal
Muzio Grilli
maritozzo is on a distinguished road
Hi everybody!!
I have to analyze the flow through an injector, i know there is not a solver for this kind of problem but first I wonna know if at least OpenFoam has the boundary conditions i need.
I decided to set the totalPressure boundary condition on the Inlet p0=p+(1/2)rho*U^2
so I specify in the pd file at time 0:
INLET
type totalPressure;
p0 uniform 12000000;
What do I have to specify in the U file
2nd question: as the time goes the velocity at the Inlet grows and consequently I should change the value of k and epsilon so i can't specify for them a fixed value but i thaught that the new k and the new epsilon should be calculated at each time step
3rd question: I decided to use K-epsilon turbulence model but at the beginning the fluid is still so intially the flow is laminar so do I have also to switch the turbulence model
Thanks
maritozzo is offline   Reply With Quote
Total pressure boundary condition maritozzo OpenFOAM Running, Solving & CFD 2 January 31, 2011 03:03
Pressure Boundary condition abishek FLUENT 1 July 28, 2008 08:14
Total pressure boundary condition bartold OpenFOAM Pre-Processing 0 November 7, 2005 08:45
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 10:06
Pressure Boundary Condition chiseung FLUENT 1 June 19, 2001 21:05
