Fourth Order Runge Kutta time integration
Like Tree39Likes
Old   August 20, 2015, 10:48
Syavash Asgari
syavash is on a distinguished road
--> FOAM FATAL IO ERROR:
keyword div(U) is undefined in dictionary "/media/syavash/science/PHD_Thesis/New/system/fvSchemes.divSchemes"
file: /media/syavash/science/PHD_Thesis/New/system/fvSchemes.divSchemes from line 30 to line 36.
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 437.
FOAM exiting
Dear Ville
I think div(U) is missing from fvSchemes. I have added it like:
div(U)          Gauss linear;
but now another error appears as follows:
--> FOAM FATAL ERROR:
incompatible dimensions for operation
    [p[0 0 -2 0 0 0 0] ] == [div(U)[0 0 -1 0 0 0 0] ]
    From function checkMethod(const fvMatrix<Type>&, const GeometricField<Type, fvPatchField, volMesh>&)
    in file /home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude/fvMatrix.C at line 1356.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  void Foam::checkMethod<double>(Foam::fvMatrix<double> const&, Foam::DimensionedField<double, Foam::volMesh> const&, char const*) at ??:?
 at ??:?
 at ??:?
#5  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
 at ??:?
Aborted (core dumped)
I suppose this error implies inconsistancy in pressure units which you expressed above. How can I resolve this problem now?!
Syavash
syavash is offline   Reply With Quote
Old   August 20, 2015, 13:04
Syavash Asgari
I changed the pressure dimension in 0/p to [ 0 2 -1 0 0 0 0 ] and the simulation goes on!
But I think a clarification on fvSchemes helps me a lot!
Another point is that I can only see pressure residuals on the screen. How should I include velocity residuals either?!
Syavash
Edit: Can you post an example of fvSchemes & fvSolution files?!
Old   August 21, 2015, 11:09
Syavash Asgari
Originally Posted by ville View Post
Sure. Please bare in mind that the conclusions I've made on runtime differences
were mostly for turbulent flows in parallel runs. Full conclusions are probably
depending on the number of processors, the parallel system which you use, the linear solver, the case (e.g. laminar vs turbulent). Good to start with lid driven cavity and check if you can reproduce the Ghia's data.
Dear Ville,
Any comments?!
Old   February 25, 2016, 05:12
Frédéric Aulery
Braxus is on a distinguished road
Dear All,
Il read this topic and succefully do the implementation of rk4 time scheme.
Is someone have some return to do about it ?
I have the same error than you, but i dislike the new pressure dimension, may we have not well do some operation.
I try the simulation of blasius boundary flow, and the time step down to 1.e-150 any idea.
Thank you for answers.
Braxus is offline   Reply With Quote
Old   December 3, 2016, 22:32
Frank Ann
ajogajog is on a distinguished road
Large-eddy simulation in a complex hill terrain enabled by a compact fractional step OpenFOAM® solver
http://www.sciencedirect.com/science...65997814001513
Best wishes,
Ville
Dear Ville,
I have read your paper and your code. you have done a wonderful work in this and help me a lot.
but i still have some questions, i cannot figure it out.
1>as we know, the rk4 is a fully explicit method, in openfoam, the explicit equation should use the fvc::ddt. but you use the fvm::ddt in code, such as
solve(fvm::ddt(rho) + rhokcycle0 * RK4values[cycle]); (solve rho)
why? and what's the meaning?
2> can we implement the time schemes directly in folder? in this way, maybe we can use the RK4 in all of the solvers
thank you !!!
Best,
Frank
ajogajog is offline   Reply With Quote
Old   April 15, 2017, 11:24
Default The code lacks a deltaT parameter in the pressure step in "PressureCorrection.H"
  #26
Yu Cheng
chengyu is on a distinguished road
Originally Posted by syavash View Post
FOAM aborting
 at ??:?
 at ??:?
 at ??:?
Syavash
Obviously, it is a problem of time dimension, the reason is a lack of deltaT parameter on the construction of pressure correction, plz refer to Projection method, see the "Chorin's projection method" part.
To help the one who is interested, I paste the corresponding code down here
// PressureCorrection.H
#include "continuityErrs.H"
U.correctBoundaryConditions();
solve(pEqn == fvc::div(U)/runTime.deltaT());
U = U - fvc::grad(p)*runTime.deltaT();
chengyu is offline   Reply With Quote
Old   March 18, 2018, 04:23
Syavash Asgari
Thanks fo your comment Yu Cheng. I have implemented the RK4 solver with the help of Dr. Vuorinen and your comment. Please check the file attached and let me know if there is something not right with the solver.
Kind Regards,
Syavash
Old   March 18, 2018, 20:58
Default Test case
  #28
Yu Cheng
Thank you for sharing the code, Syavash. Could you kindly attach a minimum test case for the code, for example maybe a small case changing the OpenFOAM cavity. I believe this will help the other foamers.
Best regards,
Yu CHENG
Old   March 22, 2018, 14:21
Syavash Asgari
Best regards,
Yu CHENG
Dear Yu Cheng,
Very good idea. I have modified the solver to be able to take a constant source term into account. I have also provided a lid-driven cavity example with the new RK4Foam solver. I hope the other foamers would find it useful and hopefully do some experiments and comparisons.
Kind Regards,
Syavash
Old   March 22, 2018, 21:23
Default Good work
  #30
Yu Cheng
Hey Syavash,
You've done a great work! I have compiled the code and run the cavity case, the preliminary results seem to be reasonable. I believe this work will definitely help other foamers. Thank you!
Best wishes!
Yu.
Old   October 22, 2018, 08:01
anonymous
rr3245 is on a distinguished road
Hey Syavash,
Best wishes!
Yu.
Hi Yu,
I have implemented this solver and I'm comparing it to pimpleFoam. It's compiling fine and also seems to be solving. However, I have two questions:
(1) What is the justification for multiplying or dividing by runTime.deltaT()? I can see that we need this for dimensional purposes, but how will this change the solver? Will this term factorise out?
(2) How will residuals be affected? I seem to have very high initial pressure residuals in the rk4projection method (compared to my pimpleFoam case). I'm using the same fvSolution specs for both cases, so I didn't expect this.
Thanks, RH.
rr3245 is offline   Reply With Quote
Old   April 3, 2019, 14:56
agSilverMAN
kermelosh is on a distinguished road
Hey Syavash,
Thank you for the solver and the test case. I was able to compile the solver and run the test case with out a glitch. I tried comparing the solver running time between the RK4Foam and pisoFoam and found out that while the results are almost identical, the RK4Foam took more than 5 times the solver time of the pisoFOAM. The case I run was the cavity case with RE = 2500 and implementing RAS modeling. I was under the impression that RK4Foam results in saving of solver running time. Is that wrong or is there something I am doing wrong?
Thanks
kermelosh is offline   Reply With Quote
Old   April 4, 2019, 03:01
anonymous
Originally Posted by kermelosh View Post
Hey Syavash,
Thanks
I have the same problem, it doesn't run anywhere near as fast as I was expecting. RH.
Old   April 4, 2019, 05:30
Syavash Asgari
Hey Syavash,
Thanks
The runtime depends on the number of processes as well. I have compared both pisoFoam and RK4 in LES simulations with cell number in order of 1e+8 and over 100 processes. I found them quite equally fast.
However, it should be noted that in RK4 solver, the pressure equation (elliptic) is solved 4 times while in pisoFoam it is solved only 2 times in default! This is the main reason why RK4 could be slower than pisoFoam in some cases.
In the end, I stick with pisoFoam as I found it more robust and more accurate in some canonical flow simulations!
Best Regards,
Syavash
Old   April 4, 2019, 05:36
Syavash Asgari
Originally Posted by rr3245 View Post
Hi Yu,
Thanks, RH.
The deltaT term is multiplied by because simply it is there in the original N-S equations! Have a look at some numerical textbook on Runge-Kutta algorithm.
Best Regards,
Syavash
Old   April 4, 2019, 05:37
anonymous
Best Regards,
Syavash
I ensured that the pressure equation was also being solved 4 times in piso and pimpleFOAM in order to make a direct comparison with RK4. I found no speed-up, in fact the times were very similar, if not slower. RH.
Old   April 4, 2019, 05:42
Syavash Asgari
I guess the main motive behind RK4 was its temporal accuracy (4th order) over PISO with 2nd order accuracy. Some acoustic solvers may benefit from that. Putting it aside, I see no particular reason to use RK4 over pisoFoam.
Best Regards,
Syavash
Old   April 4, 2019, 05:50
anonymous
Best Regards,
Syavash
The one positive I had was stability. I tested it on the Taylor-Green 3D vortex flow, and at certain points in the simulation, piso/pimple were crashing. RK4 was running fine however. RH.
Old   April 7, 2019, 15:34
Santiago Lopez Castano
Santiago is on a distinguished road
Best Regards,
Syavash
It is very important if you need at least (and at most) 2nd order accuracy in time for the non-linear term....
Santiago is offline   Reply With Quote
Old   May 21, 2019, 10:45
Smile
  #40
Hongsheng
Hen Cruise is on a distinguished road
Dear Yu Cheng,
Kind Regards,
Syavash
Hi, syavash, thanks very much for your great work, and i want to know,
Is it possible to modified the 'RK4' be an convenient 'option' in fvschemes file for ddtSchemes such as 'Euler' or 'backward'? then used for most compressible or incompressible solvers?
Hen Cruise is offline   Reply With Quote
Runge Kutta 4th Order Source Code sugu Main CFD Forum 4 October 26, 2012 03:15
Runge-Kutta 4rd Order method help for 6DoF in CFD siw Main CFD Forum 0 August 29, 2008 06:08
runge kutta Shuo Main CFD Forum 0 January 7, 2008 19:29
4th and 5th Order TVD Runge-Kutta Methods saygin Main CFD Forum 2 January 30, 2006 11:45
Runge Kutta vs adams bashforth time marching vasanth Main CFD Forum 5 January 1, 2006 00:17
