June 23, 2005, 11:35 |
I'm new to OpenFoam
Daniel Kenny
I'm new to OpenFoam (and CFD) and I would just like to take the opportunity to say how impressed I am with it so far (having worked my way through all of the tutorials). :o) However, probably because I have little experience in this, I am having difficulty in setting up a simulation to model the gas flow through a small orifice. The approach I have taken is to have two large reservoirs connected by a small tunnel. My problem is how do I set the first reservoir to atmospheric pressure and the other to a low pressure? I tried setting one wall of the first reservoir to 'atmosphere' (as in the interFOAM tutorial example). Is it possible to set the equivalent wall in the 2nd reservoir to a low pressure and hey presto a gas flow through the orifice will result or am I just coming at it from completely the wrong direction and need to read a heck of a lot more about CFD before even attempting this? Hope you guys can help. Dan |
June 23, 2005, 13:18 |
Setting the two reservoirs to
Rep Power: 22 |
Setting the two reservoirs to different pressures will indeed induce flow between them through the orifice. To set a non-uniform initial field look at the setGammaDamBreak utility which is part of the damBreak tutorial.
Which application are you running? |
Flow past orifice | aurel | Main CFD Forum | 0 | January 27, 2009 06:46 |
Turbulence modelling validation : Orifice flow | Joe | Main CFD Forum | 2 | July 26, 2006 16:41 |
Orifice Flow | John Eichler | Main CFD Forum | 1 | November 6, 2002 12:26 |
Orifice plate flow | Kyle Kisebach | Main CFD Forum | 2 | June 8, 2001 09:55 |
Orifice Flow | Prateep Chatterjee | FLUENT | 4 | February 23, 2001 14:59 |
