OpenFOAM is working for this
Old   April 20, 2005, 04:55
Default Hi!I am new for the OF. Using
Sergiy Krasnokutskiy
nobody_ua is on a distinguished road
Hi!I am new for the OF. Using OpenFOAM it is possible to solve the following problem? I need to simulate liquid flow during a process of pumping from open reservoir (like a lagoon). A liquid is a homogenous viscous waste similar to highly viscous oil.
nobody_ua is offline   Reply With Quote
Old   April 20, 2005, 05:49
Default Can you assume the flyuid to b
henry is on a distinguished road
Can you assume the flyuid to be Newtonian? If not do you have an appropriate non-Newtonian viscosity model?
henry is offline   Reply With Quote
Old   April 20, 2005, 06:00
Default Yes, I assume that the fluid i
Yes, I assume that the fluid is Newtonian.
Old   April 20, 2005, 06:03
Default I am not sure of the details o
I am not sure of the details of your case but I am pretty sure standard OpenFOAM solvers will cover it.
Old   April 20, 2005, 06:11
Default Thank you for help.
Thank you for help.
PostChannel utility not working in OpenFoam 15 nishant_hull OpenFOAM Running, Solving & CFD 15 January 18, 2012 05:26
OpenFOAM Message Board Email notification stopped working mbeaudoin OpenFOAM Bugs 3 January 8, 2009 22:08
My OpenFoam stop working can anyone help please qtian OpenFOAM Running, Solving & CFD 0 February 19, 2008 16:55
OpenFOAM users in Munich OpenFOAM benutzer in M%c3%bcnchen jaswi OpenFOAM 0 August 3, 2007 13:11
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 08:54
