Artificial jump in turbulent quantities across cyclic patch in slice of 360 deg flow
Old   March 26, 2009, 10:21
Default Artificial jump in turbulent quantities across cyclic patch in slice of 360 deg flow
Nat Trask
natrask is on a distinguished road
I'm running a compressible realizableKE model on a 90 degree slice of an injector geometry. For some reason, I have a factor of 2 jump in epsilon across the cyclic patch, and also a smaller jump in k. Has anyone encountered a similar problem? My boundary conditions are cyclic across patch, with zeroGradient at walls and fixed value at inlet for both k and for epsilon.
-Nat
natrask is offline   Reply With Quote
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
