Divergence of rhoSonicfoam at low Mach Numbers
Old   April 17, 2009, 12:17
Default Divergence of rhoSonicfoam at low Mach Numbers
Joern Bader
joern is on a distinguished road
For my Diplom Thesis i'm trying to solve a NACA0012 (Ma 0.8, 1.25°) based on the Euler-Equations with OpenFOAM.
As a Solver for the Euler-Equiations i found rhoSonicfoam.
This solver semms to Solve the decoupled Euler-Equations.
My Problem with this solver is, that this Solver is absolute unstable. My Naca Profile allways gets a Courant Number of < 4e25 after a few Timesteps. It makes no difference if I lower DeltaT or chance U.
I would post my blockmeshdict here but i think this makes no sence, because i get a similar problems with the forwardstep from the tutorials.
The forwardstep is stable if i use the predefined Flow of Mach 3. If I use an other speed also this case diverges. I tried Mach 0.8, 1, 2 and 4.
I really don't understand, why this solver is unstable for other Mach numbers than 3.
Does anyone know, why this happens and/or how i can solve this problem?
If not: Is there any other Solver in OF to solve the Euler Equations?
tell me, if some more information is needed.
thx,
Jörn
PS: i use OF 1.4.1
joern is offline   Reply With Quote
Old   April 17, 2009, 18:07
Joern Bader
I have still no Idea why the solver diverges, but i have futher information.
I tried to solve my NACA0012 and forward_step test case at different Mach numbers with rhoSonicfoam and with rhopSonicfoam. Both solvers only converge at Mach 3.
I also tried to initialize U and phi with potentialfoam but it also had no effect.
Old   April 17, 2009, 18:40
Mihir
mihir1310 is on a distinguished road
i have the same trouble with rhoSonicFoam for supersonic free jet ...
i used variable timestepping as a cure, BUt that still does not cure the problem . using a coarser mesh may help
mihir1310 is offline   Reply With Quote
Old   April 18, 2009, 05:26
xinguang cui
flying is on a distinguished road
In fact, I only would give you some guess about it. it is very possible there is no enough dissipation.As you have said, with coarser mesh, there is more dissipation. I only remember there is artificial viscous could help to give more dissipation or you need viscous term. It is only some part of memory. I wish it could be some hint.
flying is offline   Reply With Quote
Old   April 18, 2009, 07:57
Joern Bader
Thx for the replys.
A coarser mesh doesn't solve the problem. I tried a really coarse mesh with the same results.
my real problem is, that my diplom thesis is based on the Euler-Equations. I want to simulate a compressible, inviscid flow.
My idea, why these solver diverge is, that the discretisation of OF is only semi-implicit. If you look at a real div(rho*U) discretisation, you get:
Int [div(rho U)] dx = ... ~= Sum_f [rho_f U_f * S_f]
In a full implicit Method you would interpolate U_f at time n+1.
OF uses a field phi at this point but phi contains U_f*S_f at time n. At this point the Euler Equations get decoupled and the Sover can only be semi-implicit.
I think there the solver looses his stability, rather the stability of a full implicit method.
Has anyone a hint, how I can get a full implicit method in OF?
Old   April 18, 2009, 11:28
Mihir
joern
ill definitely give that a try . I am a new entrant to both cfd [both theory & practice ] .
however one interesting thing is that in one similar thread [well we are not the first & last users of these solvers who face this issue] , Dr. Jasak said emphatically that there is nothing wrong in the solvers & that its all got to do with the BC & ICs .. so lets see
Old   April 18, 2009, 11:37
Joern Bader
i never thought, that we are the first with this problem.
This problem is too obvious, becaus the forward_step case from the tutorial has the same problem if you just change the speed U.
do you have a link to the other thread? i haven't found it.
Old   April 18, 2009, 11:39
Mihir
no i do not have a link to that post .. He did not say more than that anyway. but there are many such threads on rhoSonic , rhoSimple .
Old   April 21, 2009, 04:45
Joern Bader
i'm not through with testing but i think i found the solution of this problem.
first of all: i think the boundary conditions of the forward_step case are wrong.
I thought about this because even the tutorial case just ran for Mach 3 and nothing else.
The (wrong) boundary conditons are:
inlet: U=fixedValue, p=fixedValue
outlet: U=zeroGradient, p=zeroGradient
I refer to Jasaks PhD Thesis. The boundary conditions should be:
inlet: U=fixedValue, p=zeroGradient
outlet: U=zeroGradient, p=fixedValue
if you give a fixed value for U and p in one cell, U just explodes in this cell after some iterations.
This change makes the forward_step case stable for Mach 2, 3, 4, 7 (tested).
with this change my NACA case ran for much longer but didn't get stable.
the real point for the rhoSonic solver is, that you have to limit the div Schemes.
I have no proof for it so at moment its just a claim, but i think this solver is very simple in his structure. If you then use a simple, unbounded Scheme it gets unstable. It will crash even for CoNum<<1.
In my first tests i used "Gauss linear" Scheme for div. Now i tested "limitedlinear 1" and the solver got stable over 15 sec simulation time with deltaT=0.0001 for Mach 0.8 and Mach 4.
And the results are ok.
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
non-dimensional analysis in Fluent Endee FLUENT 8 September 7, 2005 16:16
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Compressible code at low Mach numbers Peter Main CFD Forum 7 May 15, 2003 07:12
TVD scheme at low Mach number Axel Rohde Main CFD Forum 5 August 6, 1999 02:01
