Urban scenario - tetra vs hex problem
Old   March 30, 2009, 13:05
Default Urban scenario - tetra vs hex problem
Pablo Grazziotin
pablocg is on a distinguished road
Hello all!
I've been trying to run some cases of airflow around buildings using simpleFoam.
Simulations seem to converge fine when using a hexahedral mesh. However, if I try the same case but with a tetrahedral mesh, I get fast increasing time step continuity and bounding epsilon errors.
Any suggestions?
Right now I'm trying increasing numbers of Non Orthogonal Correctors, but without much success. My checkMesh results showed
Mesh non-orthogonality Max: 65.5343 average: 19.5644
Non-orthogonality check OK.
Should I be using such correctors for this? And how many? Is there some simple way of determining the number of correctors based on the mesh non-orthogonality? Or is my problem something else entirely?
Thanks,
-Pablo
pablocg is offline   Reply With Quote
Old   March 30, 2009, 13:20
ZHOU Bin
Location: Nanjing/Torino, Nanjing/Piemente, China/Italy
zhoubinwx is on a distinguished road
Send a message via ICQ to zhoubinwx Send a message via MSN to zhoubinwx Send a message via Skype™ to zhoubinwx
Hi Pablo,
I have some experience with coarse mesh on uniform flow around a cylinder. Here I use very coarse mesh(because I want to use the converged results as initial condition for my fine-mesh test case). After the residual for p and U is of order 10^(-6), I see increasing time step continuity and bounding epsilon errors afterwards. But when I use fine mesh I have no such phenomena.
Therefore, may I suggest to use fine mesh? Of course there maybe other reasons. Other friends could give you good suggestions
Bin
zhoubinwx is offline   Reply With Quote
Old   March 30, 2009, 14:01
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Let me highlight this question. Although I have no answer to this question it can be of highly practical interest for all of us using tetrahedral mesh!
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   April 1, 2009, 09:41
Pablo Grazziotin
Still haven't managed to get this to run properly with tetrahedral.
I did refine the mesh around the building (testing with just 1 at the moment), but my time step continuity error goes to E+30 within 3-4 steps.
Any other ideas?
Thanks.
Old   April 2, 2009, 03:46
matej forman
matejfor is on a distinguished road
Just to make sure, do you have some prism layer in your tet mesh?
What BC you have for epsilon and k at inlet? Are they realistic? and initial condition? You may try mapFields from the hex mesh to tet and see if it is able to continue from a good solution field with tetmesh. How does your fvSchemes look like?
matej
matejfor is offline   Reply With Quote
Old   April 6, 2009, 10:39
Pablo Grazziotin
Originally Posted by matejfor View Post
I'm not sure, think not... Am using GAMBIT size functions and Tet/Hybrid elements. To be honest, I hadn't heard of such issue before...
These are fine. U, k and epsilon are based on the following equations:
Uinlet == ufric*log((z+z0)/(Ka*z0)) * vector(1,0,0);
kinlet == ufric2/::sqrt(0.09);
epsiloninlet == ufric2*ufric/(Ka * (z+z0));
No, havent tried this yet.
matej
I'm using pretty much the simplest schemes for now, until I can get it to run properly so I can try to refine it:
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss upwind;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,R) Gauss upwind;
div(R) Gauss linear;
div(phi,nuTilda) Gauss upwind;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
Any help/ideas/suggestions are appreciated.
Thanks,
-Pablo
Old   April 9, 2009, 03:14
matej forman
by prism layer I mean a layer of typically prism-shaped elements in the boundary region for the BL better description. But your problem is not a quality of the solution but the existence of it.
What you may try is some limiting off the convection terms, something like:
div(phi,U) Gauss UpwindV cellLimited leastSquares 1.0;
or maybe 0.5.
My problem with divergence of epsilon and continuity is typically wrong BC setting, mainly of k and epsilon at inlet. I recall someone here recently suggesting setting epsilon for the initial condition 10 times higher then that of the inlet.
good luck
matej
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
ICEM CFD 5.1 problem with tetra count Baskaran CFX 2 March 13, 2006 12:59
ICEM meshing problem Forrest CFX 4 May 25, 2005 18:37
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 09:11
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
