icoFsiFoam usage
Old   April 17, 2009, 11:31
Default icoFsiFoam usage
Antonio Attili
wizard1301 is on a distinguished road
Hi
I would like to try the icoFsiFoam I download with the -dev version of OF1.5. Is there somewhere a simple tutorial or someone has a simple case that I can run. I don't know how to create the two mesh for the solid and fluid zones, create initial condition and so on.
Thank you so much
Antonio
wizard1301 is offline   Reply With Quote
Fluid Structure Interaction using icoFsiFoam Problems lr103476 OpenFOAM Running, Solving & CFD 79 August 7, 2014 09:30
IcoFsiFoam simulation crashes when using a smaller timestep mathieu OpenFOAM Running, Solving & CFD 1 May 17, 2009 03:54
How to increase memory usage by fluent Anastasios Georgoulas FLUENT 2 December 29, 2008 05:41
IcofsiFoam not supported under released 141 package pi06jl6 OpenFOAM Running, Solving & CFD 4 June 26, 2008 13:59
Errors in running a icoFsiFoam case jin_xu OpenFOAM Pre-Processing 0 June 9, 2008 06:48
