movingConeTopo tutorial from 1.5-dev crashes with Floating Point Exception
Old   April 23, 2009, 11:50
Default movingConeTopo tutorial from 1.5-dev crashes with Floating Point Exception
jaswi is on a distinguished road
Dear Forum Users and Developers
Good Evening.
I tried the movingConeTopo tutorial as given in dev version. (pulled out on 21st April 2009). and it crashes with the floating point exception. The debug info shows the following:
Stack trace:
#0 0x000000000043c38c in Foam::divideEqOp2<double, double>:: operator() (this=0x7fff08391cf0, x=@0x7b0b10, y=@0x7fff08391d00) at /home/jaswi/OpenFOAM/OpenFOAM-1.5-dev-debug/src/OpenFOAM/lnInclude/ops.H:75
#1 0x000000000043de97 in VectorSpaceOps<3, 0>::eqOpS<Foam::VectorSpace<Foam::Vector<double>, double, 3>, double, Foam::divideEqOp2<double, double> > (vs=@0x7b0b10, s=@0x7fff08391d00, eo={<No data fields>}) at /home/jaswi/OpenFOAM/OpenFOAM-1.5-dev-debug/src/OpenFOAM/lnInclude/VectorSpaceM.H:12
#2 0x000000000043ded3 in Foam::VectorSpace<Foam::Vector<double>, double, 3>:: operator/= (this=0x7b0b10, s=0) at /home/jaswi/OpenFOAM/OpenFOAM-1.5-dev-debug/src/OpenFOAM/lnInclude/VectorSpaceI.H:236
#3 0x000000000044e49e in Foam::Field<Foam::Vector<double> >:: operator/= (this=0x77f480, f=@0x79bbb8) at /home/jaswi/OpenFOAM/OpenFOAM-1.5-dev-debug/src/OpenFOAM/lnInclude/Field.C:716
#4 0x00002ba4a525ebef in Foam:: primitiveMesh::makeCellCentresAndVols (this=0x783180, fCtrs=@0x794190, fAreas=@0x79d0c0, cellCtrs=@0x77f480, cellVols=@0x79bbb0) at meshes/primitiveMesh/primitiveMeshCellCentresAndVols.C:158
#5 0x00002ba4a525ee55 in Foam:: primitiveMesh::calcCellCentresAndVols (this=0x783180) at meshes/primitiveMesh/primitiveMeshCellCentresAndVols.C:67
#6 0x00002ba4a525eeed in Foam:: primitiveMesh::cellVolumes (this=0x783180) at meshes/primitiveMesh/primitiveMeshCellCentresAndVols.C:180
#7 0x00002ba4a40164a1 in Foam::fvMesh::V (this=0x7830c0) at fvMesh/fvMeshGeometry.C:327
#8 0x00002ba4a403ae10 in Foam::fvMesh::movePoints (this=0x7830c0, p=@0x7dcd48) at fvMesh/fvMesh.C:515
#9 0x00002ba4a7945946 in Foam::movingConeTopoFvMesh::update (this=0x7830c0) at movingConeTopoFvMesh/movingConeTopoFvMesh.C:388
#10 0x00000000004357a2 in main (argc=1, argv=0x7fff08395168) at icoDyMFoam.C:67
Here is the same information with some detailed information of the variables in different frames 0-4:
frame 0:
(gdb) frame 0
(gdb) info args
this = (const Foam::divideEqOp2<double, double> * const) 0x7fff08391cf0
x = (double &) @0x7b0b10: 0
y = (const double &) @0x7fff08391d00: 0
frame 1:
(gdb) frame 1
(gdb) info args
vs = (Foam::VectorSpace<Foam::Vector<double>, double, 3> &) @0x7b0b10: {v_ = {0, 0, 7.1115353432685034e-32}}
s = (const scalar &) @0x7fff08391d00: 0
eo = {<No data fields>}
(gdb) info locals
No locals.
frame 2:
(gdb) frame 2
(gdb) info args
this = (Foam::VectorSpace<Foam::Vector<double>, double, 3> * const) 0x7b0b10
s = 0
(gdb) info locals
No locals.
frame 3:
(gdb) frame 3
(gdb) info args
this = (Foam::Field<Foam::Vector<double> > * const) 0x77f480
f = (const Foam::UList<double> &) @0x79bbb8: {v_ = 0x7a7eb0, size_ = 82}
(gdb) info locals
i = 76
frame 4:
(gdb) frame 4
(gdb) info args
this = (const class Foam:: primitiveMesh * const) 0x783180
fCtrs = (const vectorField &) @0x794190: {<Foam::refCount> = {count_ = 0}, <Foam::List<Foam::Vector<double> >> = {<Foam::UList<Foam::Vector<double> >> = {v_ = 0x79e150, size_ = 356}, <No data fields>}, static typeName = <optimized out>}
fAreas = (const vectorField &) @0x79d0c0: {<Foam::refCount> = {count_ = 0}, <Foam::List<Foam::Vector<double> >> = {<Foam::UList<Foam::Vector<double> >> = {v_ = 0x7d5fd0, size_ = 356}, <No data fields>}, static typeName = <optimized out>}
cellCtrs = (vectorField &) @0x77f480: {<Foam::refCount> = {count_ = 0}, <Foam::List<Foam::Vector<double> >> = {<Foam::UList<Foam::Vector<double> >> = {v_ = 0x7b03f0, size_ = 82}, <No data fields>}, static typeName = <optimized out>}
cellVols = (scalarField &) @0x79bbb0: {<Foam::refCount> = {count_ = 0}, <Foam::List<double>> = {<Foam::UList<double>> = {v_ = 0x7a7eb0, size_ = 82}, <No data fields>}, static typeName = <optimized out>}
(gdb) info locals
own = (const labelList &) @0x7833b0: {<Foam::UList<int>> = {v_ = 0x7e8580, size_ = 356}, <No data fields>}
nei = (const labelList &) @0x783420: {<Foam::UList<int>> = {v_ = 0x785f60, size_ = 136}, <No data fields>}
cEst = {<Foam::refCount> = {count_ = 0}, <Foam::List<Foam::Vector<double> >> = {<Foam::UList<Foam::Vector<double> >> = {v_ = 0x7b0e20, size_ = 82}, <No data fields>}, static typeName = <optimized out>}
nCellFaces = {<Foam::refCount> = {count_ = 0}, <Foam::List<int>> = {<Foam::UList<int>> = {v_ = 0x799fc0, size_ = 82}, <No data fields>}, static typeName = <optimized out>}
As can be seen from the state of the variables in frame 0, there is zero by zero division (0/0) and it is causing the crash.
Hope I was not wrong in pointing this out. I am in now way claiming that code is not functioning as described. I hope that some body might have met the same error and give me some tip.
Thanks for the attention
Kind Regards
Jaswi
jaswi is offline   Reply With Quote
Old   April 25, 2009, 04:42
Henrik Rusche
henrik is on a distinguished road
Dear Jaswi,
sorry, I cannot reproduce your problem with revision 1208. May I suggest that you recompile everything from scratch.
rmoall
./Allwmake
Best Regards,
Henrik
henrik is offline   Reply With Quote
Old   April 26, 2009, 10:21
Dear Henrik
The version I am using is latest. I am not sure which version was that but nevertheless I will update my source code and recompile. In the mean time could you please send me the case setup you tested.
Kind Regards
Jaswi
Error : floating point exception; overflow. maryam CFX 3 May 18, 2010 07:44
Floating Point Exception?? Alex FLUENT 2 April 21, 2009 01:29
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
Floating point exception during the initialisation Julie Polyakh FLUENT 1 January 6, 2004 23:07
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
