dynamic mesh motion (angularOscillatingDisplacement) in OF1.6
Old   May 12, 2010, 11:29
Default dynamic mesh motion (angularOscillatingDisplacement) in OF1.6
Tamás Baksa
tamas.baksa.hu is on a distinguished road
Dear Foamers,
I'd like to simulate the flow around an oscillating cross-section. The shape is very simple it is almost like a rectangle. I had to define very fine boundary layer resolution in order to stay below y+<1. The chord length of my shape is 1 [m] and the first cell next to the wall is 0.04e-3 [m].
My constant/dynamicMeshDict looks like:
dynamicFvMesh     dynamicMotionSolverFvMesh;
solver                  displacementLaplacian;
motionSolverLibs    ("libfvMotionSolvers.so");
diffusivity             quadratic inverseDistance 1(fixedWalls);
I have defined 0/pointDisplacement like the following:
boundaryField
    [inlet, outlet, frontAndBack description]
    fixedWalls
        type            angularOscillatingDisplacement;
        //  angle = angle0_ + amplitude_*sin(omega_*t.value());
        axis            (0 0 1);                //  direction
        origin          (0 0 0);
        angle0         0;
        amplitude     0.17453;              //  10 deg in rad
        omega         6.2832;               //  1Hz * (2pi)
        value           uniform (0 0 0);    //  ???
Using this configuration and moveDynamicMesh utililty severely non-orthogonal faces appear at angle = 0.59° and runs until the following error at angle = 1.83°:
Mesh non-orthogonality Max: 179.989 average: 7.45988
   *Number of severely non-orthogonal faces: 318.
 ***Number of non-orthogonality errors: 50.
 ***Error in face pyramids: 204 faces are incorrectly oriented.
In the next timestep OF exits and the mesh looks like in the following figure. The boundary layer mesh should remain parallel to the wall during the whole cycle.
http://img526.imageshack.us/img526/7...edmesha183.png
Do you have any idea how to avoid this?
1) Maybe using different diffusivity fields? According to Jasak and Tukovic paper [1] I should try diffusivity proportional to the distortion energy. But none of the available diffusivity keywords sound like dist. energy in OF1.6:
10
uniform
quadratic
file
motionDirectional
inverseDistance
inversePointDistance
inverseFaceDistance
directional
inverseVolume
exponential
2) Shall I define different sets for near field (BL mesh) and far field then rotate the near field set rigidly? I have found a similar case [2] but it was used in OF1.3. There is no subsetMotionSolverFvMesh in dynamicFvMesh keyword list in OF1.6:
5
dynamicMotionSolverFvMesh     // I'm using this one
solidBodyMotionFvMesh
dynamicRefineFvMesh
dynamicInkJetFvMesh
staticFvMesh                          //  mesh has no motion
Any idea is appreciated! Thanks in advance.
ps: my time step is sufficiently small, I think: 2e-4
[1] http://powerlab.fsb.hr/ped/kturbo/Op...tionFAMENA.pdf
[2] http://www.aero.lr.tudelft.nl/~frank/index.php?id=research/cfd/problems/2D_movingmesh_wing
tamas.baksa.hu is offline   Reply With Quote
Old   May 13, 2010, 05:43
egp
egp's Avatar
Eric Paterson
egp is on a distinguished road
Why not look at 1.5-dev? subsetMotionSolverFvMesh is there for you to use, or at least learn what to do and then re-implement in 1.6.
egp is offline   Reply With Quote
Old   May 13, 2010, 10:53
Kevin Smith
kev4573 is on a distinguished road
If you can conform your mesh around the body to a circle, you could use GGI to oscillate the body, which would avoid mesh deformation. Take a look at the mixerGGI example and code, it is fairly easy to change the driving function to a cosine signal.
If you don't want to change your mesh or simply cannot conform the mesh surrounding the body to a circle, I would look into the subset motion as Eric mentioned or RBF mesh motion.
kev4573 is offline   Reply With Quote
Old   May 13, 2010, 11:16
egp
egp's Avatar
Eric Paterson
But Kevin, GGI is only in 1.5-dev, and the OP is using 1.6....
Old   May 13, 2010, 12:22
Kevin Smith
Ah, you are correct.
dynamic mesh on a hexa grid Manoj Kumar FLUENT 4 August 8, 2010 08:28
Turbulent problems during Dynamic Mesh Motion arturojortega FLUENT 2 June 2, 2009 10:33
Discrete Values for Mesh Motion UnderwaterAlex CFX 2 February 21, 2008 18:21
dynamic mesh on a hexa grid Manoj Kumar FLUENT 0 August 21, 2007 07:41
Dynamic mesh + grid adapt = Crash! (Files included BillH FLUENT 4 July 24, 2007 15:31
